kevin64
Message 1 of 4
Download speed greater than DSL connection rate?
I wonder if someone could help me? I ran a speedtest yesterday and I noticed my download speed is greater than my
DSL connection rate, and both of these are greater than my IP profile. Do I need to be concerned about this? I give the results below:
Download speedachieved during the test was - 20436 Kbps
 For your connection, the acceptable range of speedsis 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :20171 Kbps(DOWN-STREAM), 1164 Kbps(UP-STREAM)
 IP Profile for your line is - 17000 Kbps
I also give my hub readings (although this has been reset since the speedtest)
Connection Information
Line stateConnected
Connection time0 days, 15:42:31
Downstream19,891 Kbps
Upstream1,148 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeInterleaved
Noise margin (Down/Up)6.0 dB / 6.5 dB
Line attenuation (Down/Up)18.8 dB / 7.3 dB
Output power (Down/Up)30.1 dBm / 1.7 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)5808 / 0
CRC Errors (Down/Up)351 / 0
HEC Errors (Down/Up)20085 / 0
Error Seconds (Local/Remote)204 / 0
 Thank you in advance, kevin.
3 REPLIES 3
Message 2 of 4
Re: Download speed greater than DSL connection rate?
if everything is running ok then I wouldn't be bothered about it
kevin64
Message 3 of 4
Thank you so much for the quick reply. Yes everything seems ok.
 I noticed on the speedtester FAQ it says 'This is the actual rate achieved during the Performance Test. This rate will never reach the IP profile rate and this is normal.'
I just thought this may indicate a problem.
   thanks again,
   kevinSmiley Happy
Message 4 of 4
no
just enjoy your great connection - I'm jealousSmiley Wink
