How long are you able to download previous BT bills for, and is there a way to get bills no longer available online emailed to you.
Solved! Go to Solution.
Hi @jack1289,
You should be able to see the last 6 months worth of bills online. If you need a copy of your bill which is older than 6 months, you can request a paper copy by ringing 0800 800 150.
PaddyB
