ironman123
Recognised Expert
Message 1 of 2
DrayTex 2750n power adapter.?
I have just recieved a DrayTex 2750n,but it`s power adapter seems to be the AU/NZ one instead of the UK version judging by the diagrams in the manual.
It has an Input of 110/240v but it`s cycles [Hz] reading is 47.5Hz,in the UK it should be 50Hz,is it ok to use it.?
Imo it should be ok,but just thought I would get a second opion.
1 REPLY 1
ironman123
Recognised Expert
Message 2 of 2
Re: DrayTex 2750n power adapter.?
Problem solved,
I checked again and the lable reads 47-63Hz,so np:)
