Message 1 of 2
Draytek 130, Google Nest
Hi, I have tried searching the forum before posting this but cannot seem to find anything that describes the issue I am having.
I have a Draytek Vigor 130 which is in Bridge mode, I have set the Draytek to 101 for the Vlan but every time I try to configure the Nest it says Configuring PPPoE failed.  Please note that VLAN ID tagging is not supported.
I am at my wits end with this.  I deliberately changed from Sky broadband to BT to be able to use the Nest Wifi and now and wondering if I have made a big mistake 😞
Any help would be appreciated.
1 REPLY 1
Message 2 of 2
Re: Draytek 130, Google Nest
Hi @Dleifne78 , I'm having exactly the same issue as you.
I'm with Plusnet but the circumstances are the same. I have a TP-Link TD-W9970, I only just bought it because I read that it would work but Google WiFi stopped that idea.
Please let me know if you have found a fix or solution because I'll pulling my hair out!
