Showing results forΒ
Search instead forΒ
Did you mean:Β
jamjar62
Expert
Message 31 of 38
Re: Draytek Vigour 2750n Vs 2830n Vs 2850n .
well thats one advantage of buying off someone whos used it in the uk on the auction site πŸ™‚ you know it has the right adaptor
JamJar62
jamjar62
Expert
Message 32 of 38
From my good friend at iwantrouters.com
http://www.iwantrouters.com/section.php/3/1/home_user/31ad033b00696c453ee7d801673e6f86
They are official draytek sellers, and are very reasonably priced too (there are other retailers), but have a look at the link above.
don,t seem to find the 2750n type 12v power supply ?
JamJar62
stelee
Message 33 of 38
Ill drop him an email, update you later πŸ™‚
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------BT Infinity 2 | 80/20 | SamKnowsβ„’ Infinity 2 Member | (EASBF)
Stephen
jamjar62
Expert
Message 34 of 38
many thanks i,ll await the post πŸ™‚
JamJar62
GPR
Message 35 of 38
Taking the step, Draytek Vigour 2850n or Draytek Vigour 2850vn
Hi,
I would like buy the Drayek vigour 2850n or Drayek vigour 2850vn can I ask a few questions ?
I am just a learning networks and would like to ask for help please.
1. What is the difference between Drayek vigour 2850n or Drayek vigour 2850vn
2.On setup I will not have a internet connection so the following link
   http://www.draytek.co.uk/support/kb/kb_vigor_v2750_setup.html
   does this give a complete setup and can I download and print off so to follow the instruction?
3. I am a online gamer PC/ PS3 MW3 ..BF3 ... and need the best connection I can my line will receive,
    at the moment I am on upto 20MB/s and always get between 15/16 MB/s wired and wireless.
Message 36 of 38
Re: Taking the step, Draytek Vigour 2850n or Draytek Vigour 2850vn
GPR
First point is are you aware these are primarily VDSL modem routers although thay also have ADSL facilities? A 20 Mb/s connection is normally ADSL and there are cheaper routers in Draytek's range that will offer ADSL connections. These are only worth the extra if you plan to upgrade to FTTC at some point.
1) The 2850vn has two phone sockets to allow a VOIP service.
2) Those settings are for the BT Infinity VDSL set up on the 2750n. The 2850n also requires setting of the VLAN for Infinity the BT Retail VDSL service but the screens will be different.
3) The 2850 like most Draytek routers are not designed for the novice but they do offer a lot of configurable options like port forwarding, QOS etc etc which can improve connections but they lack wizards and easy set up guides that consumer kit comes with.
GPR
Message 37 of 38
Thanks for the advice , I have Infinity switched on today , is there a guide on the internet where I can print?
Message 38 of 38
Not a lot around. The Draytek.com site is a lot better than their UK agent's but you need to register for some stuff and access to the forums.
