Message 1 of 38
Draytek Vigour 2750n Vs 2830n Vs 2850n .
Pondering over these three, i guess there is not too much difference in the 28** series according to this comparison,
THIS LIST
What would you choose? 🙂
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------BT Infinity 2 | 80/20 | SamKnows™ Infinity 2 Member | (EASBF)
Stephen
37 REPLIES 37
Message 2 of 38
Re: Draytek Vigour 2750n Vs 2830n Vs 2850n .
Draytek Vigor 2850n
As the 2830n apparantly is not totally vdsl/2 compliant in that chart.
Stephen
Newbie
Message 3 of 38
Hi
I am currently looking to replace my BT kit and at the moment am leaning towards the 2850
Message 4 of 38
Easy to set up with the 2850 infinity FAQ on Draytek site.
Stephen
Message 5 of 38
doesnt it say on the draytek site that the 2850 through put speed is 50Mbps, the 2750 is 100Mbps...
Message 6 of 38
Both the 2750 and 2850 have 100Mbp/s throughtput.
Note to people choosing other routers, in my experience a lot of other routers max out at about 20-30Mb/s, as they were really designed to be used as ADSL routers (max 24Mb/s). So you are buying an Infinity 40Mb/s service but then limiting yourself by choice of router to 20Mb/s. Smiley Surprised
This is one area the BT homebhub routers are good as they have no problem working at 40Mb/s and above for those people trialing 80Mb/s
Message 7 of 38
Just a word of warning - after numerous issues with my 2850n I sent it back for a replacement
Message 8 of 38
im most likely going to go for the 2750n over the other 2, would i be wrong in going for this? i want something to replace both OR modem and HH3, and give me a solid connection be able to DMZ and view connection stats. are there any other brands that make something similar that maybe better to replace both OR modem and HH3? cheers
Recognised Expert
Message 9 of 38
I have used a 2750n for about 4 months now,and have never had any downtime,unless I want it.
The 2750n is not an easy device to setup,but when done it is very reliable in my opion.
I have posted a lot of info in some of my other threads on here about QoS settings etc.
If you get the 2750,then feel free to post here if you need help with setting it up [no wireless probs though,as I don`t use it].
DMZ,port forwarding,and lots of other sections work fine,and the stats info etc is cool.
Expert
Message 10 of 38
What if you just want the basic set up as i,m not a gamer is it easy to set up ? as i noticed just a page on the website to set it up which look easy 🙂
JamJar62
