Recognised Expert
Message 11 of 38
Re: Draytek Vigour 2750n Vs 2830n Vs 2850n .
Yep!,if you just want a basic setup for browsing/uploading/downloading,watching vids email etc,then no problem.
The QoS section can help keeping it stable,but it should be ok using the defaults.
Distinguished Guru
Message 12 of 38
Just as Ironman says, the default setup is just a five minute easy peasy job.
toekneem
(EASBF)
Expert
Message 13 of 38
many thanks good advice ..sorry if i,m thick but what is meant by
The QoS section ? as used in your reply below
JamJar62
Recognised Expert
Message 14 of 38
It is not a big deal for normal use,but QoS [Qualty Of Service] is used to balance the bandwidth and port use between different protacols,to try to stop any of them hogging the whole network.
But for normal use [no servers being run by you HTML/FTP or even game servers],the defaults are fine.
DMZ is also used on a gaming server [you hosting],to help clients keep connected or connect.
But DMZ should not be left on as it leaves the PC [server] open to attack from the net.
Distinguished Guru
Message 15 of 38
Traffic priority, have a read here:
http://www.draytek.co.uk/support/kb_vigor_qos.html
toekneem
(EASBF)
Expert
Message 16 of 38
thanks very interesting and again help me understand something ha! 🙂
JamJar62
Message 17 of 38
have just had infinty installed, and have no issues getting the vigor 2750 to work or any other cable router.
After 2 days i have given up on hh3 as it keeps rebooting
my vigor 2750
1: reboots as well even though connects fine - running latest beta but tried with 1.4.1 and 1.5.1
2: port forwardung and dns service unable to configure
ive tried a cheap cable router netgear and this is fine no issues. I would like to use the draytek but need some guidance to set it up stably!!
many thanks
Recognised Expert
Message 18 of 38
jocat0,
Are you using wifi or ethernet.?
Have you checked that the "Always On" setting in the PPPoE section is set,if not it will disconnect depending on the setting.?
Message 19 of 38
Yes i had the connection set to always on so not sure what issue may have been? I also having issues withnport forwarding
With the draytek. Very frustating!!
Message 20 of 38
I have disconnected it for the time and will retry this weekend. I have tempoarraily connected annold netgear router to or modem and this has not
Diaconnected in 24 hours.
