_i
Message 1 of 2
Dreadful Pings and Web delays Again...
Well, back to what appears to be situation normal  more often than notwith the BT network in the last few weeks.
Ping has started…
PING 217.47.106.122 (217.47.106.122): 56 data bytes
Request timeout for icmp_seq 0
64 bytes from 217.47.106.122: icmp_seq=0 ttl=126 time=1104.659 ms
64 bytes from 217.47.106.122: icmp_seq=1 ttl=126 time=1098.085 ms
64 bytes from 217.47.106.122: icmp_seq=2 ttl=126 time=1332.583 ms
64 bytes from 217.47.106.122: icmp_seq=3 ttl=126 time=1286.077 ms
64 bytes from 217.47.106.122: icmp_seq=4 ttl=126 time=1207.897 ms
64 bytes from 217.47.106.122: icmp_seq=5 ttl=126 time=1029.306 ms
64 bytes from 217.47.106.122: icmp_seq=6 ttl=126 time=1490.561 ms
64 bytes from 217.47.106.122: icmp_seq=7 ttl=126 time=1230.612 ms
64 bytes from 217.47.106.122: icmp_seq=8 ttl=126 time=1020.436 ms
64 bytes from 217.47.106.122: icmp_seq=9 ttl=126 time=1002.735 ms
--- 217.47.106.122 ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 1002.735/1180.295/1490.561/150.433 ms
1 REPLY 1
PaddyB
Moderator
Moderator
Message 2 of 2
Re: Dreadful Pings and Web delays Again...
Hi _i,
How are things with your connection now? Could you try running the BT Speed tester and posting back your results. You will need to run the "Further Diagnostics" once the first test completes.
PaddyB
