Steve_Baker
Message 11 of 14
Re: Drop in Sync and D/L speed again
Much cleaner, now if the mods could ask the powers that be for me to un banded I think I might be onto a winner.
Connection time0 days, 0:01:02
Downstream2,272 Kbps
Upstream804 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)29.2 dB / 5.7 dB
Line attenuation (Down/Up)35.0 dB / 19.4 dB
Output power (Down/Up)20.4 dBm / 12.4 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 20005
Error Seconds (Local)0
Steve
Guru
Message 12 of 14
I expected to see a better margin than that ... seeing as you thought cable segregation was an issue .....
Sure you've done all you can?
Are you in test socket? ....  if not don't do it now, wait until daylight hours before rebooting router.
Steve_Baker
Message 13 of 14
Something seems to be happening:
Connection time0 days, 2:20:36
Downstream7,318 Kbps
Upstream828 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)14.5 dB / 6.0 dB
Line attenuation (Down/Up)35.0 dB / 19.3 dB
Output power (Down/Up)20.7 dBm / 12.3 dBm
Loss of Framing (Local)11
Loss of Signal (Local)1
FEC Errors (Down/Up)2242 / 2
CRC Errors (Down/Up)7 / 2147480000
HEC Errors (Down/Up)nil / 20007
Error Seconds (Local)5
Steve
Guru
Message 14 of 14
That's more like it ....  let it cook a bit now , no more resets.   😉
