Message 1 of 10
Drop in broadband speed - BT Hub 1.5
I recently noticed a drop in my broadband speed. Speed is 5-6meg to my premises, but only .5 to 1.5meg from the BT Hub 1.5. I've normally connect via wifi, so I connected my PC directly to the hub via the ethernet (PC was upstairs and I set it up downstairs next to the hub). The was no increase in speed.
I've spoken to the tech team (via chat) and I have been told that my exchange has been updated, and my "old" BT Hub cannot cope with the new signal.
I've been told that a "new" hub would solve the problem. Is this the case?
I need to have this confirmed before I pay for a new hub (hub3 or 4, I suppose).
Please help Smiley Frustrated
Mazz71
9 REPLIES 9
Message 2 of 10
Re: Drop in broadband speed - BT Hub 1.5
The hh1.5 should work with the exchange if upgraded to adsl2. Post the adsl stats from your router enter 192.168.1.254 into your browser
Message 3 of 10
Hi
Thanks for the reply.
Post my stats? Which page are you refering to on the hub page?
Mazz
Message 4 of 10
I don't use a hub anymore but they used to be in advanced and then adsl. If you look at a few other posts you will see the stats required
Message 5 of 10
Thanks.
I'm lost 😞
But thanks for the help
Mazz
Message 6 of 10
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 7 of 10
this link shows you the adsl stats you need
Message 8 of 10
Thanks again for the help, but I'm unable to find the correct screen.
The help screen refers to the hub 1,2 and 3 but not 1.5
I'm not very good at this, am i? 😞
Mazz
Message 9 of 10
the hub 1 details apply to your hub as well
Message 10 of 10
Thanks for the help anyway. Im not able to find the correct page, but I again thank you. I'll speak to the BT tech team on Monday
Mazz
