Stephy1982
Message 1 of 4
E-mail not sending...
Hi is there a limit on how much data you can send in an email as im trying to mail 11MB and its seems to be stuck and i try to delete it from outlook and it just says that its being transmitted.
please help if someone can Robot Happy
3 REPLIES 3
syops
Recognised Expert
Message 2 of 4
Re: E-mail not sending...
Do you know your upload speed? A file that size will take a while to upload and transmit. (about 5 min on adslmax)
Check your exchange or major service outages
If someone has given a helpful answer, please click on their Ratings star on the left-hand side. 🙂 ***
Distinguished Guru
Message 3 of 4
Hi. Welcome to the forums.
An 11MB file will effectively be around 15MB allowing for overheads. At upload speed of around 50KB/s on adslmax, this will take about 5 minutes to send.
There is a limit per email - I believe it's around 25MB including attachments (again allow for overheads).
Stephy1982
Message 4 of 4
Thanks for your help 😄
