Message 1 of 17
E-mail setting for THREE network
Hi. I am using a Galaxy S3 and I am on the THREE network. I can receive e-mails no problems but not send them.
Is there a seting I need to change? Basically, THREE have said this. Help please.
Do they support email forwarding via third party?
- Do they support outgoing email traffic via any other port other than Port 25 or 587, 465 or 486?
16 REPLIES 16
Message 2 of 17
Re: E-mail setting for THREE network
You would have to ask Three, as this forum can only help with BT Broadband problems.
This page should help.
http://www.three.co.uk/Support/Calls_Email_and_Messages
Message 3 of 17
THREE are referring me back to BT. I can't get a simple answer from the online people, they want to charge me £30! Is there another BT E-mail forum?
Distinguished Guru
Message 4 of 17
Hi. Welcome to the forums.
I assume you are referring to sending "three" emails via BTYahoo! ?
What error message are you receiving when trying to send ? Typically ISPs (probably as well as mobile type companies) prevent non connected users from using their mail servers. So in order to send "three" emails you need to go through address verification using your BTinternet email address. See my shortcuts, link below, option 0e
Message 5 of 17
I cannot see what this has to do with BT, if you are on the Three network, as they are your service provider?
Message 6 of 17
Make sure that in the email outgoing settings you have the "Require sign-in" box ticked.
Message 7 of 17
Because BT supply me with the e-mail
Message 8 of 17
Maybe I didnt explain as well as I should have done.
I have a BT Yahoo account, all set up on the Galaxy S3 I have, via the Three Network. I can receive mail no worries, but it refuses to send them. It just simply says sending failed. I assume this is something to do with the outgoing configuration. I was hoping to find out if I need to change the config or something like that.
Cheers
Craig
Message 9 of 17
I use an S2 and outgoing for bt yahoo mail
server  mail.btinternet.com
security  none
port  587
requires sign in  yes
authentication   auto
username  ****@btinternet.com
then the password
works for me on pop3
Message 10 of 17
security  none
port  587
authentication   auto
then the password
Would that be on the THREE network?
Cheers
