Message 1 of 13
Echolife HG8110H-20 has died
Hi all. Woke out this morning to no internet and a flashing purple light on the hub. Tried usual reboot of the hub etc with no joy, so checked the modem and behold it has no lights and seemingly no power.
I tried unplugging and back in, different plug socket, and even tracked down an alternate power supply from a different device with the exact same connector, but sadly nothing.
I have an engineer due at some point Monday (it’s Saturday AM), but with both kids at home sick  it’s already causing unnecessary hassle
Anyone got any clever ideas? I have looked online to buy a new one but it wouldn’t be here until Wednesday the earliest.
12 REPLIES 12
Message 2 of 13
Re: Echolife HG8110H-20 has died
@pmcclean
What type of BT Internet connection do you have?
I assume its FTTP, in that case there is nothing you can buy to replace it.
Message 3 of 13
Hi - it’s FTTP 900
Message 4 of 13
So is it just a case of waiting for the engineer? I was mildly concerned they would not have a modem in their standard kit, meaning it would be a few days after that before I got sent a new one.
Message 5 of 13
@pmcclean wrote:
Hi - it’s FTTP 900
There is nothing you can do, they are specifically registered to your connection.
Its usually the power supply that fails.
Message 6 of 13
Super. Thanks for the quick response.
Message 7 of 13
FYI, buying one on the internet wouldn’t help, the device has to be authenticated onto the system using its serial number  , so a replacement ONT would still need the OR technician to enter that info so that the headend will ‘communicate’ with the ONT
Message 8 of 13
Are you sure that the spare power supply that you tried, was the same voltage and the correct diameter plug that made good contact?
Message 9 of 13
I have managed to find another supply at it has done the trick (from an old handheld vax)! Might buy another as a spare in case it happens again.
Checked the original supply and it was only 5v, whereas I needed 12v
Many thanks!
Message 10 of 13
Many thanks!
Excellent 😀
