MJD
Message 1 of 5
Email Sign-in Seal
I have set up my Email sign-in seal on a number of occasions over the last year.....but after a while the sign-in seal disappears!!!!
It is a worry ..... is there a valid reason for this loss?
Mike D
4 REPLIES 4
Moderator-Retired
Message 2 of 5
Re: Email Sign-in Seal
Hi Mike,
Have you deleted cookies/temporary internet files or changed browsers around the time when the sign-in seal disappears? There shouldn't be any reason behind it disappearing on its own. This thread (albeit a few months old) might clarify things for you.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Keith_300
Newbie
Message 3 of 5
Hi. I have the same problem as the o/p.  I frequently delete cookies but the sign-in seal is usually unaffected. I have not changed browser but i did recently use a different one as a one-off (to get round a problem). Is that what caused the seal to vanish?
Distinguished Guru
Distinguished Guru
Message 4 of 5
I also delete cookies regularly, but use CCleaner (free) because it can preserve settings by letting you keeping selected cookies. If you fancy trying it, the saving facility is at Options > Cookies; just move any you want to keep to the right-hand pane. It copes well with multiple browsers.
Distinguished Guru
Distinguished Guru
Message 5 of 5
There's a new post here that might be helpful: http://community.bt.com/t5/Other-BB-Queries/BTY-sign-in-seal/m-p/409407#M15212.
