Message 1 of 7
Email access
Recently started having access problems, in trying to log into my emails. Message keeps coming back, 'cant reach this page'. Have tried changing my password, as suggested, this did work ok for a few days, but now back to square one, same message appearing.
This is becoming very frustrating, obviously something has happened to the system to cause these problems, after many years of no problems.
Can anyone help here?
6 REPLIES 6
Message 2 of 7
Re: Email access
Are you a BT Broadband customer or are you paying for your email through a BT Premium Email account?
Do you know if you are on the BTYahoo email system or BTMail system.
Have you tried clearing your browser's history and cookies? If not try doing that and if the browser has the option, clear it from all time.
Message 3 of 7
Re: Email access
I am a BT broadband customer, and think use BT Mail system, not Yahoo.
Have clear browser history as recommended, still no luck in logging onto emails.
Message 4 of 7
Re: Email access
A couple of things to try. Try another browser and if that doesn't work try turning off your Homehub for about 15 minutes. When you turn it back on hopefully you will be connected to a different email server and this may allow access to your account.
Message 5 of 7
Re: Email access
have tried disconnecting Hub, no help. Not sure about trying another browser, why should I, when it has worked fine for a number of yrs. My problem I feel lies with BT, i have done nothing to effect the process, so must be a problem at BT end, just not sure how you contact them.
Message 6 of 7
Re: Email access
You don't have to try a different browser if you don't want to. It was suggested as a bit of diagnostics to try and establish where the fault might lie.
Phone 0800.800.150
Message 7 of 7
Re: Email access
sorry if my comment came over as a criticism, i do appreciate your suggestions, just getting a little frustrated. Interestingly, have tried another few times to log on, and eventually it has worked. Does not make sense.
