RTL
Message 1 of 9
Email addresses.
With BT Mail I am entitled to 11 email addresses.  I have two questions. I have one account that I let slip and it is now defunct.  The thing is that it is still counting against my quota. I still have the password and don't require anything from the account. How can I reinstate it? Or is that it--lost forever?
Second question. I am getting a lot of spam on another account which BT doesn't filter out. When it passes thru to Outlook, it detects it most of the time and sticks it in the junk folder. My question is:- If I delete that account does it still count against my quota or does it give me back an available slot?
8 REPLIES 8
gg30340
Message 2 of 9
Re: Email addresses.
Depending on when the email account became "defunct" will depend on whether or not is still counts in your running total and whether or not it can be reinstated.
If it has gone past the recovery time it should drop off your running total and give you back the "slot".
If you decide to set up a new email address you can not re-use any of your previously used email addresses even if the are now permanently deleted.
See Links
http://bt.custhelp.com/app/answers/detail/a_id/44499/c/7339
http://bt.custhelp.com/app/answers/detail/a_id/44861/c/7339,7368,7408
RTL
Message 3 of 9
Thanks for your answer. I had already looked at those items.  The defunct account is well passed the recovery time  but is still being counted in my used quota. If I go into My BT and list the addresses, it is there. The slot has never been returned.   This is what is making me wary about deleting the account that is being spammed. I realise one can't use an email address that has previously been used and have already created a new one.  My intention was then to go to the sites where I use this address and give them the new one.  Then delete the spammed one. But if it doesn't return the slot, then I'll have lost another one!
gg30340
Message 4 of 9
There has been a glitch in the past where deleted email accounts were not being cleared and freeing up the slot. If this has happened to you you can not do anything about it. It will take BT intervention to clear it/them.
RTL
Message 5 of 9
25 minutes on the phone to BT. Fortunately it was to Blackburn and not India!  BT's answer is that when I create an email address, that is counted as one of my 11 addresses.  If it goes defunct or I delete it, it will still count as one of my addresses.  It doesn't give you that "slot" back.
gg30340
Message 6 of 9
They are wrong. You have a running total and if you delete one you get that "slot" back.
I have notified the moderators of the forum about your problem. Once they have read this they may be able to help. They are a BT UK based team and if they can help they will reply via this thread asking you to contact them via a link. They are very busy at present so once you have replied to them by the link, it can take over 48 hours for them to re-contact you.
RTL
Message 7 of 9
Thanks for your time and responses. Much appreciated.
PaddyB
Moderator
Moderator
Message 8 of 9
Hi @RTL,
What @gg30340 has said is correct. Once you delete an email address it should free up space for you to create another. I'm sorry this hasn't happened in your case. I'll be able to get this corrected.
Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
RTL
Message 9 of 9
Contacted by Stuart ( Moderator) and he has done the necessary. Email quota now as it should be.  Have now created two additional addresses and changed my login details on all the sites that were using the spammed address. After that I deleted the spammed one. It will take 60 days so hopefully when that time comes, I will get the slot back. In the meantime I will close this thread as solved. Thanks to all concerned for their help--much appreciated.
