Keith_Beddoe
Message 11 of 49
Re: Email size decreased, advertisements increased.
Thunderbird, when configured as IMAP, downloads the spam folder, and calls it "bulk mail", where you can delete or move any message.
It also has its own spam filter which learns what is spam, and what is not.
I think you will find that you are not actually paying for email, unless you are paying for BT Premium Mail.
Its simply a Value Added Service, which you can use if you want to. Adverts help to cover the cost that BT have to pay their email provider.
Alternatively, you are free to use other email services like Gmail.
snavekj1944
Message 12 of 49
Keith, unfortunately we are not all whiz kids on computers, so why should we try other things when we are paying BT.  I am not a Techno at 73 years old.
Keith_Beddoe
Message 13 of 49
@nicos wrote:
Keith  - this is only a probelm that's occured today.
Perhaps people have been ignoring the adverts Smiley Wink
Not really sure, as I do not use webmail, just an email client.
Keith_Beddoe
Message 14 of 49
There is nothing complicated about using an email client, in fact it makes it a lot easier to use any email service.
shadders
Message 15 of 49
Hi,
I checked - BT Mail is free :
"BT Mail is free for BT Broadband customers. Just choose BT Mail when you order your broadband package."
So, it does not state that it is a Value Added Service, but then since it states it is free, then i assume we are therefore not paying for it directly.
There are no reasons for BT to restrict the view of the webmail. It is not customer friendly. We already have adverts on the sign in page.
Not everyone is technically literate to move to IMAP.
BT should keep the system as it was.
With the recent increases in charges, then this change is very unwelcome.
Regards,
Shadders.
nicos
Message 16 of 49
Hi all - this is nothing to do with whether or not BT mail is free or whether we should be seeing adverts.
The simple problem is -  the way the view of mail is presented has changed overnight.  The width of the "Mail Account" and "Advertisment" columns has increased which has reduced the width of the viewing pane for the emails.    I suspect this is a technical issue that I am hoping BT will fix.
Can someone from the BT Mail team please comment ??
johnclegg
Message 17 of 49
Another one here incensed...I am using Adblockplus which gives me a clear right hand pane , but BT gives me a much bigger pain "in the ar*e " , to say i worked for them for 37 years and they are now treating me as cr*p....
More info required about the othe way of opening mail etc.etc.
Please?
John
Keith_Beddoe
Message 18 of 49
Please?
John
Do you mean using an Email client?
You can use both an email client, and webmail (if you need to access it elsewhere)
dianacurrey
Message 19 of 49
has anyone got an answer to the problem?
johnclegg
Message 20 of 49
It's only a matter of minutes and I can now see all I need to see with Mozilla Thunderbird , just a little hiccup,seemed only wanted to import fron outlook but is now up and running and BT mail can now go and take a "running jump" , just hope their advertising clientel get wind of this....
Please let me know if BT put this back as if they do I have a soft spot for them and will return..
John 🙂
