Message 11 of 27
Re: Ending BT contract
I intend to leave BT without bartering, I can’t be bothered. So, as my contract ends on the 15th May am I correct in saying that I can switch providers on the 1st May penalty free and without having to tell BT?
Message 12 of 27
Message 13 of 27
Yes I have seen that thank you  but really, being a bit thick, is the simple answer yes or no? Thanks.
Message 14 of 27
Hi @Piecringe as your contract ends on the 15th May then as long as the new provider is taking over the service on or later than the 15th you won't have any termination charges. If the transfer was the 14th see @-Richie-  post earlier on the this thread.
Cheers
John
Message 15 of 27
So I will be safe to proceed on the 2nd May? At one second after midnight!
Message 16 of 27
You said earlier, your end date is 15th May.
Message 17 of 27
The transfer usually takes 10 - 14 days , so as stated earlier just make sure the takeover date for your new provider
is on or after the 15th May.
regards
Message 18 of 27
If bt raise there prices you have 28 days to cancel contract penalty free I've done it myself,just wait they normally raise prices at least once a year sometimes more
Message 19 of 27
That's no longer the case - see the reply to your identical post elsewhere.
Message 20 of 27
@Jimmy3
This was explained to you here https://community.bt.com/t5/Bills-Packages/Bt-contract/m-p/1936475#M108612
Please do not post misleading and out of date information, as the T&C were changed at the start of this year.
