AmAtoL
Message 1 of 20
Engi booked, hey Presto no internet !1!!11
I have an engineer booked for a home visit to try and sort out this ongoing low ip profile malarky tomorrow, came to the PC just now and tinterweb is off.
Posting via trusty VM connection.
If he shows he's bound to have a new modem on stock, so may not be a total fail.
Where will it end ?
19 REPLIES 19
Distinguished Guru
Message 2 of 20
Re: Engi booked, hey Presto no internet !1!!11
Good luck tomorrow AmAtoL. Its long overdue.
toekneem
(EASBF)
AmAtoL
Message 3 of 20
Cheers toekneem
I was looking at quite a straightforward job, but now the internet has lost connection completely, so who knows what will happen.
Probably get a new modem fitted, then have a low profile for 6 weeks, then have a new modem fitted and have a low profile for six weeks.
It's like Groundhog Day.
Playful
Message 4 of 20
Good luck mate I think mine is for Saturday 🙂
iPHAILZ
Message 5 of 20
http://btbusiness.custhelp.com/app/service_status
3RD one down is quite a big one, not in that area are you mate?
2nd one now (this does update so ill just say the manchester area one)
Best BT india advice i have seen yet on these forums:
Q: Someone has hacked my wireless network
A: Try plugging router into your test socket.
AmAtoL
Message 6 of 20
iPHAILZ, I do live in South Manchester but it seems to have come back now after being off last night.
Apparently the engineer did show according to my son, he was here "7 seconds" and said everything was working.
Quelle Surprise when I log on tonight and find my profile is still stuck at 21697, absolute waste of time.
Distinguished Guru
Message 7 of 20
maybe they will have to reset them all when they increase the Infinity speed, last I heard it was due about October time.
toekneem
(EASBF)
Playful
Message 8 of 20
That's 2 months away. Although having waited 2 months already it's not the end of the world. Amatol that's unfortunate another engineer visit required then this must be costing them a fortune 😕
AmAtoL
Message 9 of 20
Aye lads, one has to laugh.
It was organised by DeanM too, so he should have been aware what exactly he was going to do (the engi)
Good Luck tomorrow Playful, every now again they do it right 🙂
AmAtoL
Message 10 of 20
Toppage as I want to know how Playful went on 🙂
It looks like I will have to be in the house myself if another engineer arrives some time, otherwise it's back to square one.
