tansycat
Message 1 of 3
Engineers using my line?
This afternoon I have been cut off three times in the middle of a single phone conversation. The phone goes "beep beep beep", then goes dead and when I look at the handset it says "line in use" although there is no-one else using it here.
This has happened many times before and on one occasion it resulted in me being without a phoneline completely for days. When it was finally fixed I was told my line had been disconnected by mistake at the exchange.
 I have not reported any faults so why are the engineers fiddling around with my line? Can't they tell the line's in use before they cut me off?
2 REPLIES 2
Message 2 of 3
Re: Engineers using my line?
Its probably an intermittent line fault.
Check here first Fixing phone faults
If you cannot find anything wrong, then report intermittent connection here   Reporting Phone Faults
plainview
Recognised Expert
Message 3 of 3
'I was told my line had been disconnected by mistake at the exchange'
What a call centre tells you is not always what exactly happened.
