Hi,
I have just set up my new You View Ultra HD Box and Broadband and I only seem to be getting a few of the channel.
I signed up to the BT and entertainment pack but when I select one of the channel the BPT-200000 Error code comes up.
When I select Bt player on the remote it says 'There has been a a problem' followed by error code BTP-115c
Any help would be appricated!
Thanks in advance
Luke
Solved! Go to Solution.
Hi @Luke_H Sorry that you are having a fault with your BTTV service.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Hi John,
Thanks for getting back to me, I contacted BT directly too and the issue was resolved this morning.
It seems to be a very quick and easy fix but has to be done remotely by BT, nothing to do with any of my kit or lines.
Thanks again for getting back to me,
Luke
