Message 1 of 1
Error code was0003
Hi, anyone else getting the above error Cade and found a permanent solution? I keep getting this when watching you tube on the tv, the router is wired to tv. I get this error 3-4 times a week, normally have to run test and say my wireless connection is good and if error continues I should contact supplier. Which try to do but just get fed up with the automated recess which does not cover the above error code. Any help would be appreciated, thanks
