Maggie06
Message 1 of 2
Error message 2nd part of BTW
Hi when I do a speed test on btw 1st ok but on the 2nd part I get this error message and I have to reset set safari to put it right any ideas? Oh have just installed Mavericks 10.9
Maggie06
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.IllegalStateException: Cannot forward after response has been committed
	org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1078)
	org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:396)
	org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:232)
	org.apache.struts.action.ActionServlet.process(ActionServlet.java:1913)
	org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:462)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.16 logs.
1 REPLY 1
Guru
Guru
Message 2 of 2
Re: Error message 2nd part of BTW
Hi Maggie06,
Sometimes you just have to retry the Further Diagnostics part of the BTWholesale speedtester.
Though Safari does somtimes play up when trying to use it.
You could install Google Chrome or Firefox as these work better with the BTWholesale speedtester.
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
