willowen100
Message 1 of 4
Error message whilst trying to finish BT SmartTalk app
I'm trying to finish the final setup of the SmartTalk app on two different Android phones as seen here
However, I encounter this message
Both phones are logging in under their own BT ID separate to the account holder which is owned by my Dad, and obviously the setup process is somewhat working because it accepts the landline number. Any help will be appreciated.
Will
3 REPLIES 3
PaddyB
Moderator
Moderator
Message 2 of 4
Re: Error message whilst trying to finish BT SmartTalk app
HI @willowen100,
If you take a look at -Fix problems signing up to BT SmartTalk, you'll find a few steps that might help.
Give that a go and let me know how you got on.
PaddyB
willowen100
Message 3 of 4
When I sign into the SmartTalk app do I sign in with my own BT ID or the broadband holders account?
Keith_Beddoe
Message 4 of 4
If its the first one you set up, then it would be your account BT ID.
For new signups, you have to create a new BT ID, and use that to setup SmartTalk.
