Message 1 of 4
Error with BT Speed Estimator !!!
I'm currently on BT Infinity Option 1 and my profile is around 38.72/10 Mbps.
Thinking of upgrading to BT Infinity Option 2, the system estimates that my speed would be around 36/20 Mbps.
Any reason why the download speed is slower that what I'm currently getting ?
In the past when I've ran the line speed tester it estimates that I should get around 72/20 Mbps.
Is there a fault with BT's system ?
I've just tried to get an upto date profile using the BT speed tester (http://speedtest.btwholesale.com/) but it just keeps displaying an error, please try later.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Error with BT Speed Estimator !!!
Hi dsh63,
I can take a look at this for you, if you like. Please could you send me in your details using the link found in the "About Me" section of my profile?
PaddyB
Message 3 of 4
Thanks PaddyB,
I've just ran another speed estimation with BT's website and the max profile estimation is not 52.5/18 Mbps.
Recognised Expert
Message 4 of 4
I thibk there is an issue with their system, as it reports my line lower than what it actually is and has been for past year
