TeaAndToast
Message 1 of 18
Ethernet Connection - Connection and LAN Drops
Never really bother me until now, and you have been helpful in the past so here I am.  Basically I have had internet connection drops, with the yellow flashing B on the Hub, which also knocks out my LAN connection (yellow triangle).  I then have to go into my LAN connection, disable and reable.  Any ideas?
Kind Regards
T&T
17 REPLIES 17
imjolly
Message 2 of 18
Re: Ethernet Connection - Connection and LAN Drops
if you are resetting the router often can you please post your router stats
TeaAndToast
Message 3 of 18
Hi Jolly, your always about.
I never reset the router, its just the connection drops and forces the ethernet connection to do it also.  Im on windows 7 and have had this problem on another motherboard also.  Router is maybe 6 odd years old, the 2nd hub type, black one.
Edit - attached them to show whats happening.
Line stateConnected
Connection time0 days, 0:05:02
Downstream3,904 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.3 dB / 22.0 dB
Line attenuation (Down/Up)48.0 dB / 29.0 dB
Output power (Down/Up)18.1 dBm / 12.6 dBm
Loss of Framing (Local)44
Loss of Signal (Local)7
Loss of Power (Local)0
FEC Errors (Down/Up)4738 / 0
CRC Errors (Down/Up)7 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)1836
imjolly
Message 4 of 18
error seconds are high but rest looks ok
usual questions - connected to test or master?  quiet line test ok?
TeaAndToast
Message 5 of 18
Not connected to master socket. House is 2003 ish, with no master socket, Ive opened all plates to check. Ive also all cordless phones, so can't determine as never pure silence, but have used the one connected directly which seems to have a little noise.  They have the BT trumpet logo. Ive had an egnineer out before when I lived here (folks), with no success then.  It seems to happen in little frustrating bouts.  Ok for few days, and then few disconnections.  Ive changed ethernet leads and is it p45 leads.
TeaAndToast
Message 6 of 18
Happened a few times again. So repost of stats.
Line stateConnected
Connection time0 days, 0:01:50
Downstream3,264 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)6.7 dB / 22.0 dB
Output power (Down/Up)17.6 dBm / 12.6 dBm
FEC Errors (Down/Up)26098 / 0
CRC Errors (Down/Up)0 / N/A
Error Seconds (Local)3704
Keith_Beddoe
Message 7 of 18
Do you have any other equipment like a Sky box or alarm system?
TeaAndToast
Message 8 of 18
Alarm is never on and sky box is downstairs.  I do have a transmitter for watching sky, but it was beside the hub in my last house with no problems.
ps - no disconnections today.
Line stateConnected
Connection time1 day, 3:50:12
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)6.4 dB / 22.0 dB
FEC Errors (Down/Up)2173795 / 167
CRC Errors (Down/Up)742 / N/A
HEC Errors (Down/Up)N/A / 69
Error Seconds (Local)4175
john46
Message 9 of 18
is a broadband filter connected to the phone line the skybox is plugged into also the transmitter device could be causing a problem as they operate on similar frequency to the wireless channels from your hub try moving it as far away as possible from the hub
Keith_Beddoe
Message 10 of 18
See this diagram about Sky box connections
Sky Box Connections
