DS
Distinguished Guru
Message 11 of 18
Re: Ethernet Connection - Connection and LAN Drops
Keith
Somethings wrong with that link - it goes to 'an unexpected error'
An Unexpected Error has occurred.Sorry, your request failed. A notification has been sent to the development team for investigation.Exception ID: ********. Please click the Back button on your browser.
edit. Scrub that:D I see you've edited your post
-+-No longer a forum member-+-
Keith_Beddoe
Message 12 of 18
Internal web linkage issue, it should be fixed now. My website is replicated in two locations and an internal reference was wrong.
DS
Distinguished Guru
Message 13 of 18
The first (pre edit) link, the text version, did make reference to the forum address and finished with /speed/skyconns.jpg, but note your site image works perfectly:), again ending in /speed/skyconns.jpg
Keith_Beddoe
Message 14 of 18
The address http://forumhelp.dyndns.org/
is just a webhop link which directs to either my own webserver, or the free BT webspace, depending on how I configure it.
The html code has to be portable between those locations, and a couple of the references are incorrect at the moment, so just moving site over to BT space to check a few links Smiley Wink
DS
Distinguished Guru
Message 15 of 18
The working image on previous post does show me a reference to strawberryt.dyndns
Trust that's your plan
Keith_Beddoe
Message 16 of 18
It was intended to be a link, not a diagram, but it failed to resolve properly, as I think I had an extra http at the front, as a result of using the forum "insert link" tool.
It is now corrected. All links should reference the forumhelp website.
DS
Distinguished Guru
Message 17 of 18
Ok:)
edit. Back on to cbeddoe.....?
TeaAndToast
Message 18 of 18
My transmitter just plugs into the mains electric and nothing else but scart leads. Never noticed a D/C during the past 3 days, but seems it has happened whilst unused.   Everything is filtered at the wall, sky disconnected altogether. Tho I do get drops sometime when the phone rings or is used.  I have changed all filters in all sockets with no success.
Line state Connected
Connection time 0 days, 7:42:37
Downstream 4,000 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Interleaved
Noise margin (Down/Up) 5.0 dB / 18.0 dB
Line attenuation (Down/Up) 48.0 dB / 29.5 dB
Output power (Down/Up) 18.1 dBm / 12.6 dBm
Loss of Framing (Local) 56
Loss of Signal (Local) 12
Loss of Power (Local) 0
FEC Errors (Down/Up) 1848711 / 9
CRC Errors (Down/Up) 1025 / N/A
HEC Errors (Down/Up) N/A / 6
Error Seconds (Local) 6499
