Rodweiller
Message 1 of 11
Ethernet but no Wifi on BT Smart Hub 6
Any ideas please?
After about three months of installing my new Smart Hub 6, the colours changed a few times the other day and it looped for about 10 minutes (very pretty) but now, I can get ethernet but no wifi. All it says is "Secured No Internet"
I have restarted it several times. 😞
I have reset it to default. 😞
I have checked all three laptops and they work off a BT Hotspot I have elsewhere in the house 😞
I have considered hitting it with a sledge hammer at 10 to 3am this morning!!!!! 😞
Any ideas please?
10 REPLIES 10
Keith_Beddoe
Message 2 of 11
Re: Ethernet but no Wifi on BT Smart Hub 6
Do they give Internet access?
Rodweiller
Message 3 of 11
Full internet on the BT hotpot but no wifi from router. The hotpot works via Internet cable fro router to wall socket in lounge then socket hotpot on wifi with different password in bedroom. I do not want all my kids and friends on my bed with their laptops just to get wifi!!!!
Keith_Beddoe
Message 4 of 11
It does sound like another faulty HH6 if its not transmitting any wireless signal, this seems to be a common problem.
Rodweiller
Message 5 of 11
Thanks.
I could put the 5 back and return the 6?
Keith_Beddoe
Message 6 of 11
@Rodweiller wrote:
Thanks.
It would prove the fault.
Why did you bother with the HH6, as the HH5 is a better product in my opinion?
Rodweiller
Message 7 of 11
I only get about 28mb on average although when I put my landlines number in the website it said I could get up to 70mb so I upgraded in the hope it would help my speed. It didn't and then an engineer tested the line and stated I would only get about 30mb max due to the stability of the equipment so I could have just ordered the cheaper package and not buy the additional router 😵
Keith_Beddoe
Message 8 of 11
That sounds a bit odd. What speed range did the website show for Range A, when you input your number?
Brianl1964
Message 9 of 11
I have it the other way around, no ethernet for a week now, bt faults stated it was the hub . that was the end of story form the faults team sending out a recyled smart hub 6 of which only ocst £0.01 to fix
DaveD
Message 10 of 11
Put the 5 back on for more reliable service - good luck in returning the 6, I have tried and failed frustratingly
