Message 1 of 2
Ethernet cables - Smart Hub 2
Hi
Recently  installed the Smart Hub 2 and Halo 3+ with the Fibre 900 package. Just waited for speeds to settle maybe and over wi fi getting around 200mbps download and consistently 50mbps upload. Vast improvement over before but below the package expectations.
Going to try an Ethernet cable and that had me looking at getting a newer version to handle everything better and future proof.
Looking at the ones BT provided with the hardware  they state Cat5e, I was assuming they would be much more recent . Do I need to change these which connect to the Hybrid and OpenReach box (FTTP) in my quest to get the maximum out of my decision?
Many thanks
1 REPLY 1
Message 2 of 2
Re: Ethernet cables - Smart Hub 2
Cat 5E is more than adequate.
