Eddie937
Message 1 of 13
Ethernet connection drops
Hello,
This is my first time here so please be kind.
I have had my BT Home hub3 for 8 days now. I have only been able to connect to internet briefly (5 secs) with the ethernet connection yet with my wireless it's perfect. I rang up BT and had a line check done and everything is fine.
Does anyone know why my ethernet connection is not working?
Many thanks
Eddie
12 REPLIES 12
Message 2 of 13
Re: Ethernet connection drops
have you tried all the ethernet ports on the back of the HH3?  are you sure your driver for your network card is up to date?  if not then go to manufacturers website and get update.  have you tried a different ethernet cable?
Distinguished Guru
Message 3 of 13
Hi Eddie937 and welcome
Navigate to Network and Sharing Centre
Click on Manage network connections
Right click on your Local Area Connection2 and select Properties
Double left click on Internet Protocol Version 4 (TCP/IPV4)
Are there any IP address settings in the results or is obtain an IP address automatically selected?
If there are any, delete them and opt for the auto option.
Reboot, disconnect the wireless connection, connect by ethernet and see how it goes.....
-+-No longer a forum member-+-
Eddie937
Message 4 of 13
I looked at the stuff you said above and its all fine. Rebooted and connected ethernet cable. It connected for about 5 secs then said a network cable is unplugged. It then re connected after 10 secs then disconnected after 30 secs.
It keeps doing this.
Any more ideas?
Andrew
Eddie937
Message 5 of 13
Also i have tried to connect 2 other computers with the ethernet cable and the same happens on them.
s it something to do with the hub settings?
Andrew
Distinguished Guru
Message 6 of 13
Is "the ethernet cable" the same one or have you tried another one?
Have you tried the other Ethernet ports on the rear of the hub?
I'd also disconnect all devices from the hub, press the little red reset button on the rear of the hub for about 3-4 seconds, allow the hub to reboot and try connecting a PC by cable again.
If it still drops I'd have to say the hub is faulty....
jocko73
Message 7 of 13
I could be wrong but it sounds like the ethernet cable could be the problem, but if it has been changed and it's still saying network cable unplugged then I would say its the network card, as you mentioned it happens on other pc's/laptop i'm at a loss other than saying get updated drivers for network cards on all pc's/laptop
Eddie937
Message 8 of 13
The ethernet cable is the same one. I havent got a spare 😞 and yes i have tried the other ports.
Andrew
Distinguished Guru
Message 9 of 13
You need to rule out the cable - maybe borrow one from a neighbour?
Eddie937
Message 10 of 13
I will see my neighbour later to see if i can borrow his cable.
I've been to Marvell website and updated the driver and it still drops 😞
Before i was using the update driver button from device manager but that update was only 2007 now i have a 2011 update from Marvell.
