User-in-Herts
Message 1 of 2
Ethernet connection to Homehub 2 keeps dropping out
I have a Homehub2 directly connected to my desktop PC via an Ethernet cable and three laptops connected via wireless. I frequently lose the Ethernet connection but all the laptops contiue to connect via the wireless. The solution is to go through the desktop help and reload the Hub which gets the connection working for a very short period of time. I have swapped the Homehub with my od Netgear router and the problem goes away. Any help appreciated.
1 REPLY 1
Message 2 of 2
Re: Ethernet connection to Homehub 2 keeps dropping out
Hi have you checked you have up to date drivers for your network card and also no power saving setting are in operation the HH 3 has had issues with ports but nothing I can remember on the HH 2 have you tried changing ports in case it is just one faulty one
