gerzenplerter
Message 1 of 6
Ethernet speed is 6 times faster than wireless?
I have the hub mk.2, up untill recently wired and wireless speeds were very similar around 6 mbit.
Just lately wireless has dropped to 1mbit but ethernet is still 6 mbit.
I have changed the hubs channel a few times but it makes no difference. Is there a fault with my hub,if so are BT obliged to replace it for free? Thanks.
5 REPLIES 5
imjolly
Message 2 of 6
Re: Ethernet speed is 6 times faster than wireless?
wireless is normally lower than wired and less stable.  have you checked for interfernece that could be causing the wireless problem.  if you hub is faulty, and I'm not sure it is, then as long as you are still in contract then contact CS India and they will replace a faulty hub.. if your contract has expired then it is up to you to replace the router
gerzenplerter
Message 3 of 6
Thanks, I will try changing the channel again. I renewed my contract a few months ago. If I purchase the new Hub 3 will this be faster or will I just waste my money. Thanks
john46
Message 4 of 6
The home hub 3 will be the same wireless is always less reliable then a wired connection
imjolly
Message 5 of 6
if you renewed your contract then, assuming the terms are still the same as when I renewed mine recently, you HH2 warranty is extended for another year so if it is faulty again which I doubt you could get it replaced for free
tickhill
Expert
Message 6 of 6
I had similar problems with homehub 2 and was talked through a reset process.
Not just use the restart/refresh button at bottom right of the hub, but actually insert a small pin into the hole about half-way up on the right hand side of the hub.
This reset it to defaults and there was an immediate improvement.
NB - note the Admin Password and perhaps the Wireless key from the base of HH2 incase needed.
Will certainly need the Admin Password if you want to go to Hub Manager as you have to insert the default admin password then choose one of your own.
In terms of Hub3 - then elsewhere there has been some concensus that HH3 is an inferior product and can certainly say that I received one out of the blue some weeks ago and installed it with disastrous results in terms of speed and reliability.
I rapidly removed it and reinstated HH2
In general, if you can use an Ethernet cable I would consider it preferable.
Hope that is helpful.
