Newbie
Message 1 of 2
Ethernet stopped working
Hi all, had BT for about a month and it's been fine. Today whilst watching Netflix through my tv (wired to Ethernet port) it suddenly stopped. No biggie I thought and just signed into WiFi on the which worked. After finishing the show went to my pc and of turns out the Ethernet on that wouldn't connect. Tried running a troubleshoot and it said that my Ethernet doesn't have a valid IP connection. Looked on the router hub through wireless on my mobile and it appears that nothing connected with a cable is now connected to the internet. Factory reset and it's still the same. Does anyone know why this might be?
Many thanks
1 REPLY 1
Message 2 of 2
Re: Ethernet stopped working
Do you have the HH6?
If so that's the cause of your problem. It's not just you either, a lot of people have reported the same problem.
Best way to remedy it is to tie the HH6 to a brick and take it to the middle of a very deep lake and throw it in.
Then call BT and ask they post you a HH5 instead.
