Message 11 of 22
Re: Exasperated BT Broadband Customer with no sign of resolution to broadband speed issues
Unfortunately we don't seem to be able to maintain a stable connection, I've been checking regularly and we did get to about a day and a half of uptime but the router dropped the connection at about 3am this morning. Speed still very slow.
Message 12 of 22
is there anything here that could be causing inreference
interference causes
Message 13 of 22
We haven't changed any of those appliances for a number of years, I also invested in a shielded cable to replace the cheap one supplied with the hub in the hope that would mitigate any potential interference. I am a total loss? Does the event log provide any pointers when the connection is lost?
Message 14 of 22
not really just how long connection has been 'up'
Message 15 of 22
All I get from log is below, connection has just dropped again
14:10:40, 11 Aug. (273839.910000) PPP LCP Send Termination Request [User request]
Message 16 of 22
if you are connected direct to the test socket with a new filter and quiet line test is ok and connection still dropping then you need to phone customer services and get an engineer visit
08001114567
Message 17 of 22
Ok and so the loop begins again.....
Message 18 of 22
After being threatened with a £129 charge and a round with the call centre we have an engineer coming out to investigate on Friday morning on the basis the connection keeps dropping out thus not allowing the speed to 'settle' or recover.
Message 19 of 22
The warning about a possible charge is made by all providers as it is a standard charge raised by Openreach if problems are found on internal wiring or equipment connected to it as you problem is the same at the test socket then no charge should be raised
Message 20 of 22
Ok thanks, it did worry me a bit we only have bt router connected direct to the test socket. I'll update the post once the engineer has visited
