STX1300man
Message 11 of 14
Re: Exchange Upgrade - Broadband Degraded
@Roger65 wrote:
Cause of problem part of my line i.e. house to cabinet approx 40to 500 metres is aluminimum. No good for ADSL 2
That's not good news as our area is supplied over aluminium powder wrapped in PVC masquerading as a telephone cable Smiley Happy
Message 12 of 14
one of the changes I made was to fit a filtered faceplate but as you don't have any extensions then that would noy help you.  I also found that removing the wires in my master which were not in use helped
I don't know if you have seen this post which may help as it helped reduce my noise margin by moving router further from TV
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
Roger65
Message 13 of 14
I don't find your reply amusing. If you don't want help then don't post.
PS if you have got aluminiumum cable as I have been here for 30 years BT will not change it so you are stuck.
STX1300man
Message 14 of 14
I was just concurring with you that Aluminium cable is not what you want anywhere between you and the exchange. The reference to powder wrapped in PVC was about the fact a lot of the Aluminum cables have broken down over time and when removed/bent/opened the insides just crumble.
