Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Does nobody in BT do forward thinking? In an affluent village that has <1M ADSL it doesn't take a genius to work out demand for VDSL will be very high. The cost of providing a 200pair cable over a 100pair must be miniscule compared with the cost of going back and providing a second cable. Even if existing duct space is tight (I suspect they used an existing D side duct for the link cable in our case), the physical size of a 200 pair is not that greater than a 100pair. It will still have been cheaper to provide the extra duct and larger cable at day1 anyway.
Even before they switched us on BT posted that we were a 'High Demand' area, so it begs a question as to why greater capacity wasnt fitted in the first place.
Ok, so, appears we made a bit of a mistake when installing. We simply replaced the Home Hub where it already was, which was at the end of an ethernet extension from the master socket.
We have had a fiddle and moved stuff around, enabling all we need to move the HH5 to the master socket. Ive also replaced the HH telephone wire to a short twisted pair cable. It also appears we dont have a filtered faceplate (one ordered) So here are the new stats, greatly improved but still not where I believe it should be?
1. Product name: | BT Home Hub |
2. Serial number: | +068543+NQ45120544 |
3. Firmware version: | Software version 4.7.5.1.83.8.204 (Type A) Last updated 21/02/15 |
4. Board version: | BT Hub 5A |
5. DSL uptime: | 0 days, 01:09:27 |
6. Data rate: | 9997 / 29751 |
7. Maximum data rate: | 11005 / 34738 |
8. Noise margin: | 8.1 / 6.1 |
9. Line attenuation: | 23.8 / 23.4 |
10. Signal attenuation: | 23.8 / 22.4 |
11. Data sent/received: | 962.9 MB / 9.3 GB |
12. Broadband username: | bthomehub@btbroadband.com |
13. BT Wi-fi: | Yes |
14. 2.4 GHz Wireless network/SSID: | Mi6 Snooper |
15. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
16. 2.4 GHz Wireless security: | WPA2 |
17. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
18. 5 GHz Wireless network/SSID: | Mi6 Snooper |
19. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
20. 5 GHz Wireless security: | WPA2 |
21. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
22. Firewall: | Default |
23. MAC Address: | 18:1e:78:2d:b7:36 |
24. Modulation: | G.993.2 Annex B |
25. Software variant: | AA |
26. Boot loader: | 1.0.0 |
