CalamityK9
Message 1 of 17
Exchange now fibre, slow speeds?
Hi All,
         Noob here, so go easy! My exchange has just gone fibre, we were one of the lucky ones to get one of the 100 fibre slots! Our speeds were terrible at around 2mb for uploads. Since the upgrade, BT suggested we would get 36-54 mb but we actually get an average of 14.5 mb, the fastest was 15.21 mb. Clearly much less than expected. The connection has been live for 8 days, BT say give it 10 days as speeds may improve. From looking at other posts I need to post up some info, so here it is, does anything look odd, as I have no clue?
Any help/advice would be greatfully received Smiley Happy
Telephone Number 01249 on Exchange CASTLE COMBE is served by Cabinet 2
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)54.435.513.98.4--Available
FTTC Range B (Impacted)46.825.713.96--Available
ADSL MaxUp to 3.5--2.5 to 6.5Available
Fixed Rate----Available
Other Offerings
Fibre Multicast------Available
1. Product name:BT Home Hub
2. Serial number:+068543+NQ45120544
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 21/02/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 13:25:38
6. Data rate:1323 / 16226
7. Maximum data rate:1334 / 19521
8. Noise margin:6.7 / 7.0
9. Line attenuation:37.2 / 22.8
10. Signal attenuation:38.0 / 20.4
11. Data sent/received:811.5 MB / 18.5 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:No
14. 2.4 GHz Wireless network/SSID:
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:18:1e:78:2d:b7:36
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
16 REPLIES 16
john46
Message 2 of 17
Re: Exchange now fibre, slow speeds?
was it an engineer install or self install ?
pippincp
Sage
Message 3 of 17
Did you order Infinity 1 or Infinity 2?
Where does the 100 fibre slots come from as there's no cabinet in use with so few connections?
CalamityK9
Message 4 of 17
It was self install and Infinity 1 upto 38 mb, the 100 slots came from  a friend whos a BT engineer, the cabinet has 600 slots, only 100 are fibre in the initial rollout, so I'm told. Smiley Surprised
imjolly
Message 5 of 17
If self install are you connecting to test socket with a new filter?  If do you have an SSFP?
CalamityK9
Message 6 of 17
By test socket do you mean one underneath the faceplate on the master socket? if so, no. Directly into the master. Whats a SSFP?
imjolly
Message 7 of 17
That is an SSFP
 if you have extension sockets in your home can you connect to the test socket behind detachable bottom plate to eliminate any problems with your internal wiring
CalamityK9
Message 8 of 17
We don't have a SSFP then, it does have the socket beneath the lower plate, ill give that a try, thank.
Devon_Dave
Distinguished Guru
Message 9 of 17
pipincp. There is a dslam with low ports. all of them in fact if only 1 or 2 cards installed. ECI cards have 64 ports. With huawei depends on dslam type. could be a 24, 32, or 48 port variant.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
licquorice
Message 10 of 17
Or, as they seem to have done in our village, not provided sufficient pairs in the tie cable between the copper and fibre cabinets. We were enabled just before Christmas, there was a huge rush for takeup (adsl is sub 1M here!!) and orders were stopped very quickly as capacity was used up. Last week they dug the road up between the cabs to (presumably) put an extra duct and cable in. Why they didn't pull a bigger cable in in the first place I don't know!
