Devon_Dave
Distinguished Guru
Message 11 of 17
Re: Exchange now fibre, slow speeds?
I suspect they only install approx the same amount of copper as there are ports on the installed cards. so if more cards go in they need more copper.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Deathtrap3000
Recognised Expert
Message 12 of 17
Usually a 100pair cable will link the two cabs with additional capacity added (either another 100 or 50) when needed.
licquorice
Message 13 of 17
Does nobody in BT do forward thinking? In an affluent village that has <1M ADSL it doesn't take a genius to work out demand for VDSL will be very high. The cost of providing a 200pair cable over a 100pair must be miniscule compared with the cost of going back and providing a second cable. Even if existing duct space is tight (I suspect they used an existing D side duct for the link cable in our case), the physical size of a 200 pair is not that greater than a 100pair. It will still have been cheaper to provide the extra duct and larger cable at day1 anyway.
CalamityK9
Message 14 of 17
Even before they switched us on BT posted that we were a 'High Demand' area, so it begs a question as to why greater capacity wasnt fitted in the first place. Smiley Frustrated
ray_dorset
Distinguished Guru
Message 15 of 17
The fact remains that your data rate speed are below the predicted speeds for Range B which is the range used for self-installation.
If you can try the test socket and repost your helpdesk stats you may be able to see if your extension wiring is the problem.
If not, I'll try again 🙂
CalamityK9
Message 16 of 17
Ok, so, appears we made a bit of a mistake when installing. We simply replaced the Home Hub where it already was, which was at the end of an ethernet extension from the master socket.
We have had a fiddle and moved stuff around, enabling all we need to move the HH5 to the master socket. Ive also replaced the HH telephone wire to a short twisted pair cable. It also appears we dont have a filtered faceplate (one ordered) So here are the new stats, greatly improved but still not where I believe it should be?
1. Product name:BT Home Hub
2. Serial number:+068543+NQ45120544
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 21/02/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 01:09:27
6. Data rate:9997 / 29751
7. Maximum data rate:11005 / 34738
8. Noise margin:8.1 / 6.1
9. Line attenuation:23.8 / 23.4
10. Signal attenuation:23.8 / 22.4
11. Data sent/received:962.9 MB / 9.3 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:Mi6 Snooper
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:Mi6 Snooper
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:18:1e:78:2d:b7:36
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
ray_dorset
Distinguished Guru
Message 17 of 17
The stats are very improved, and a SSFP should improve them even more
