Message 1 of 2
Exchanging Phones numbers between BT-->VM and VM-->BT
Hi Everyone,
I would like  some advice on an unusual request/project, that involves porting or swapping some phone numbers. Would it be possible, do you think to simultaneously, or perform a switching of phone numbers, from Virgin to BT and from BT to Virgin?
For example, I have two other BT phone lines in my property/house. And I wanted to investigate and hopefully put into practice, a swap of my current Virgin Media phone number to BT, and one of my BT Phone Line Numbers in this case to Virgin Media?
So in other words, I am looking to retain both contracts and services. But I just wish to port and swap each phone number from BT to Virgin Media and Vice Versa, without hopefully loosing each number or contracted service in the process.
Kind regards and yours sincerely,
From Edward Powell
1 REPLY 1
Message 2 of 2
Re: Exchanging Phones numbers between BT-->VM and VM-->BT
@edwardstpowell
What you are proposing would be virtually impossible, as the BT Phone network and the VM phone network, are totally different and incompatible, and have totally different number ranges.
