Hi - the announcement last year that Exeter will be getting FTTP was fantastic. I have registered my address on the Openreach site and see that the build is underway. But their progress map never seems to change - always says "Build in Progress".
There doesn't seem to be any ongoing communications or updates to the local community. The silence is deafening. I occasionally see fibre being pulled on various streets and get very excited! But does anyone know how to get a better understanding of their rollout plan and when BT will be able to deliver FTTP to my house?
BT will be able to deliver FTTP to your house once Openreach has laid the infrastructure. Beyond that no one here can tell you.
Contact https://www.connectingdevonandsomerset.co.uk/ for an update
@pippincp - As the OP is a newbie your response as a guru was a bit abrupt, especially as @pompey1898 was able to make a suggestion
