Message 1 of 4
Expensive phone calls for faults
How do I phone BT on Pay as you go phone for free as it is costing a fortune. My husband  phoned faults today and it cost £4 for one call and I have had the same problem.
3 REPLIES 3
Message 2 of 4
Re: Expensive phone calls for faults
register for smarttalk if you have a smartphone then you can phone as if it was your home phone you are using - can use wifi or mobile phone network
Message 3 of 4
this number is charged at standard mobile rate from the mobiles inclusive minutes 0330 123 4567
Distinguished Guru
Message 4 of 4
Use a payphone, its free!
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
