can you also do quiet line test dial 17070 option 2 should be quiet and best with corded phone
You have probably had the speed boost that is mentioned in this link. If you did you will still be on Infinity 1 but it is now receiving the additional speed, it does not change you onto Infinity 2 which is a different package with other benefits.
As regards the email advising you of the speed boost, it is not unknown for BT emails to end up in the spam folder or for BT to send them to an email address that you used when you first signed up with BT but no longer use.
As requested
Done the quiet line test and no noise on the line.
Line stats fom the HG612
Connection up time: 0 days 22 hours 6 minutes & 9 seconds Last Resync recorded at 13/02/2018 22:00
Firmware version: A2pv6C038m.d24j Retrain Reason: 0
________________________________________________________________________________________________________________
Downstream Upstream Downstream Upstream
Sync (kbps) 55993 20000 Interleaving 1173 1
Attainable rate (kbps) 68816 24115 INP 3.00 0.00
Attenuation (dB) 18.7 0.0
SNR Margin (dB) 6.6 6.8
Power (dBmV) 4.8 4.8 SES (total) 0 0
RSUnCorr errors (delta) 0 0 RSUnCorr errors (total) 12113 0
Errored seconds (delta) 0 0 Errored seconds (total) 28 17
Bitswaps (delta) 36 0 Bitswaps (total) 52207 62
CRC errors (delta) 0 0 CRC errors (total) 134 17
HEC errors (delta) 0 0 HEC errors (total) 2965 0
FEC errors (delta) 23 0 FEC errors (total) 1043068 171
Your stats show you have had the boost and you connection of 55993kbps is above the max for old infinity 1 cap. However all your disconnections have caused your speed to reduce and was not your profile resetting. Your current connection time is only 22hrs is that due to modem dropping connection or manual reset
if you can get your connection stable then your speed you increase back toward attainable but could take DLM quite a few weeks
So much for the stable speeds, again speeds have dropped and ping has increased due to this whem I was at work.
Connection up time: 0 days 14 hours 4 minutes & 24 seconds Last Resync recorded at 16/02/2018 00:47
Firmware version: A2pv6C038m.d24j Retrain Reason: 1
Sync (kbps) 50714 19993 Interleaving 1513 253 (both showing as on)
Attainable rate (kbps) 68832 21570 INP 5.00 2.50
Attenuation (dB) 18.8 0.0
SNR Margin (dB) 6.5 6.5
Power (dBmV) 6.5 6.4 SES (total) 10 0
RSUnCorr errors (delta) 0 0 RSUnCorr errors (total) 963 0
Errored seconds (delta) 0 0 Errored seconds (total) 60 26
Bitswaps (delta) 20 0 Bitswaps (total) 20887 16
CRC errors (delta) 0 0 CRC errors (total) 5439 32
HEC errors (delta) 0 0 HEC errors (total) 199 0
FEC errors (delta) 41 0 FEC errors (total) 2922860 824
as your connection is still appears unstable and you are using a modem then it is not a hub problem. Have you tried connecting direct to the test socket with a filter to eliminate your internal wiring as causing a problem and also your faceplate. if you have extension sockets in other rooms then check that there is no dial tone at any socket
