etaf
Message 1 of 15
Extend BT infinity from master socket
My neice is moving into flat and the master socket is in the Bedroom - the master socket with a split data / telephone ports
the flat also has extension telelphone points around the flat
She has ordered infinity , which she already has
She does not move in until next week and as the landline has not be used for a while BT needs to re-activate 13th September
couple of Questions
As the data is split in the master socket, I assume all the telephone sockets will be voice only and not be enabed to connect the router
it would be idea if we could use the phone extension in the main living room and then connect the TV and router and now box all in one place with cable
Otherwise we have to rely on wireless which may not be so great
she has a Hub3 and Infinity modem that she has been told to take with her to the new flat , and connect it up and after the activation date it will work
Otherwise she could take a DATA cable - i assume a cat6 ethernet cable from the modem in the bedroom to the otherend of the flat - how far can the ethernet cable be extended
or can she extend the small modem cable , and take the modem to the TV - how far can this wire be extended ?
she was told she should get 60 mbps as she is next to the exchange
thanks
14 REPLIES 14
licquorice
Message 2 of 15
Re: Extend BT infinity from master socket
Just move the wires in the master socket that go to the living room from pins 2&5 to the data extension terminals. You will need to fit a filter in the living room socket.
etaf
Message 3 of 15
i'm not sure where the wires all go
all i can see is a master socket in the bedroom
and then wall flush sockets in the flat in various walls - so i assume they are all extensions and all connected 4 extensions
flat was built about 10years ago
So you suggest I open up the master socket in the bedroom and do something with the cables to enable the data to be on all the extensions like you would have with normal ADSL
not sure what pins i use for that
take off the wiring on the master data portion and connect to ??
so that all the extensions pick up the data
licquorice
Message 4 of 15
No, it would be preferable to just move the cable that goes to the living room if that is directly wired from the master socket. There are two connections labelled data extension terminals on the backplate of the master socket. The cable to the living room should be terminated on pins 2&5 on the removable faceplate which need to be moved to the data extension terminals. If the extensions are daisy chained, it might be a bit trickier. Alternatively, just run a new cable from the data extension terminals to a new RJ11 socket in the living room.
pippincp
Sage
Message 5 of 15
You can leave the Openreach modem in the bedroom and then run an ethernet cable up to 100mtrs to the other room.
etaf
Message 6 of 15
Thanks , yes i thought it was just a ethernert cable that i could run
just wondered if the thinner modem cable would extend OK
or reduce the signal
its supposed to be 60Mbps - so shes on her own in a 1 bed flat - so doesnt need that bandwidth for watching netflix , catchup tv and generl use on a iMac
thanks
Not sure how the wires are interconnected all i saw as only had 15mins in the flat with estate agent
was the faceplate fulsh to wall of all the 4 telephone extension sockets
and the surface mounted master socket
Thanks for all your quick replies
pippincp
Sage
Message 7 of 15
It is almost guaranteed extending the modem cable would result in a speed drop depending on the length. Ethernet is good for up to 100mtrs without noticable loss.
etaf
Message 8 of 15
Thanks for all your replies
If i change the Hub3 for a Hub5/6 does that actually improve the wireless signal
She watches netflix and catch up and did not have a great experiance on the old hub3 with infinity @30Mbps download - tested today
The old hub3 was in the same same room (4m x 3m )
so i'm not sure how good its goinf to be in a different room about 12m and wall away from the TV and NOW box
licquorice
Message 9 of 15
If you are considering paying for a Hub5/6, don't waste your money. Either buy a decent third party VDSL modem/router or just a standalone router and keep the Openreach modem. Thirds party routers with external aerials will have far better coverage than a Hub.
etaf
Message 10 of 15
she does not want the equipment and all the lights in the bedroom
so I guess I need to extend the RJ11 Modem cable to a different room anyway
