I have a hub 6 and i want better wifi upstairs there is an unused Ethernet cable already uptairs from the hub 6 so i just neet something that i can put on the end of the cable for wifi ,, Any suggestions
thanks
Solved! Go to Solution.
thanks
You just need a wireless access point. Google search TP Link TL-WA801ND which will be just fine.
As said by @Keith_Beddoe you just need a simple access point, and the one recommend will work fine for web browsing, streaming etc.
Although, if you have an Old Home Hub, or any other old router (preferably not a Smart Hub as people on here seem to be having problems)
If you have one, you can post back for help with the settings that have to be changed.
Hi i could give it a try i have hub 3 if any good
i think also a hub 5 maybe , how do i set up
any help appreciated
thanks
Home Hub 5 preferable, but the lights indicating no internet (even though technically there is) will flash, this won’t happen on the HH3.
Guide here (for both, they share the same interface): http://unixetc.co.uk/2014/03/04/reuse-a-spare-bt-home-hub-as-a-wireless-access-point/
A cut piece of black insulation tape fixes that!
THANKS 👍
No problem 😊 Did you get it working?
