tharris
Message 1 of 4
Extension socket with built in ADSL filter
Hi. I've got an existing extension socket box with a phone and adsl router connected via a microfilter. I'd like to tidy things up a bit by replacing the box with one which has a built in filter and a socket each for phone and adsl, but for some reason I can't find anyone selling one. It seems there are plenty of master socket faceplates available to do this, but I'm baffled at how difficult it's proving to find an extension box to do the same? Do they exist?
3 REPLIES 3
imjolly
Message 2 of 4
Re: Extension socket with built in ADSL filter
if your router is connected to youe extension socket with a filter i assume the filtered master socket is not used for your broadband connection    not using the master socket may well reduce your conenction speed
filtered faceplates as far as I am aware are masters   you could always switch master to an extension and vice versa
tharris
Message 3 of 4
The master socket has only a telephone connected, via another plug in microfilter. The master socket is not in a suitable location for the router. The broadband speed is fine despite being via the extension. The extension socket needs replacing for cosmetic reasons anyway and I'd just like to take the opportunity to smarten things up further by having the filter built in, which I had expected five minutes on Amazon or Ebay would take care of. Seemingly not.
imjolly
Message 4 of 4
so really the solution is as I said swap the master and extension and then use filtered faceplate on the new master (old extension socket)
some telephone engineer out of local paper as openreach would be expensive
