Message 11 of 14
Re: Extreme fluctuations with download speed
@stp wrote:
Did you enter your phone number or service id number? I entered my phone number.
Still getting the same message.
I used my phone number
Message 12 of 14
well, tried it both yesterday and today and tried the test in Opera,Firefox and IE, it's not working for me.
Are there any other speed test sites that i could use to display details of my connection?
Distinguished Guru
Message 13 of 14
The BT speedtester can be erratic, sometimes working , sometimes not working.
There are other speedtests that you can use, how accurate they are i will leave for others to answer.
These other speedtests will not show your profile, and if you are looking to speak to support about your speeds etc, they will need BT's test .
www.Speedtest.net
[edit] BT speedtester working here @ 20.46
toekneem
(EASBF)
Sage
Message 14 of 14
If using speedtest.net make sure you select either the London (Namesco) server or the Paris one as these are the most consistant and reliable ones.
