hover2u
Message 1 of 22
Extremely Slow BB Speed
Having resolved one problem with my BT BB, a new one starts. Every evening (from about 2000) my broadband speed drops to the point that it is impossible to load web pages (even the google home page takes for ages to load). I've tried running the speedtester over the last couple of nights and all I get is the error message "We haven't been able to complete the speed test at this time. This may be due to a problem with the speed tester, or your line may be running very slowly." Any ideas?
Tags (1)
21 REPLIES 21
imjolly
Message 2 of 22
Re: Extremely Slow BB Speed
can you posts your adsl stats from your router please
hover2u
Message 3 of 22
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:38:17
Downstream:1.117 Mbps
Upstream:1004 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Interleaved
Noise margin (Down/Up):7.2 dB / 6.3 dB
Line attenuation (Down/Up):53.1 dB / 30.0 dB
Output power (Down/Up):15.3 dBm / 12.6 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):42237 / 38
imjolly
Message 4 of 22
can you go back to stats and then show detail and post rest of errors
hover2u
Message 5 of 22
ADSL Line Status
Connection time:0 days, 00:55:55
Upstream:1004 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):7.3 dB / 6.1 dB
CRC Events (Down/Up):70762 / 39
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):18521 / 11
Error Seconds (Local/Remote):3343 / 3
imjolly
Message 6 of 22
your crc/hec errors and error seconds are very high for <1hr connected and that is the reason for the poor download/throughput.
your connection speed is low for your attenuation as I would expect about 4/4.5mb
are you connected to the master or preferably the test socket  do you have other sockets in other rooms?
hover2u
Message 7 of 22
Any suggestions on how I can resolve this? I haven't changed my setup in months apart from BT replacing my HH a couple of months ago due to connection problems.
hover2u
Message 8 of 22
Sorry. I'm connected to master socket and have no other sockets in the house.
imjolly
Message 9 of 22
if you have a test socket can you connect to that please.  can you try quiet line test  dial 17070 option 2  should hear nothing and best with corded phone  if cordless then dull hum normal
john46
Message 10 of 22
You could also look at this post it may help you reduce the errors http://community.bt.com/t5/BB-Speed-Connection-Issues/Poor-Broadband-speed/m-p/14217#M8397
