Gareth064
Message 1 of 10
Extremely Slow Speeds in the evening.
Apologies for another post like this, this forum send to be full of them, but I didn't want to hijack someone elses post.
Since mid December my infinity 1 speed in the evening has been between 1mb and 2mb. During the day I get 20mb-30mb.
I have been reading elsewhere that BT don't throttle and it's more than likely congestion at my exchange, which is LONGSTRATTON Cabinet 9.
Is anyone like a mod able to confirm if there is any reported congestion problems at my exchange? Or does anyone have any suggestions on how I can troubleshoot poor speeds in the evening only?
Tags (1)
9 REPLIES 9
john46
Message 2 of 10
Re: Extremely Slow Speeds in the evening.
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Gareth064
Message 3 of 10
Will do John. What I'll do tomorrow is a test during the day and then again the same test on the evening and then post back.
Gareth064
Message 4 of 10
On bt wholesale speed test, do i need to do the tap test by changing my login on the router in order to get the results you want?
Webby
Message 5 of 10
No, just the further diagnostics test.
Keith_Beddoe
Message 6 of 10
The TAP3 test is not needed, and cannot be run on a BT home hub anyway.
Gareth064
Message 7 of 10
This is the results from the day time. I will do the same test again this evening when it appears to get slower.
1. Best Effort Test: -provides background information.
Download Speed
22.05 Mbps
0 Mbps 38.01 Mbps
Max Achievable Speed
Download speedachieved during the test was - 22.05 Mbps
For your connection, the acceptable range of speedsis 26.6 Mbps-38.01 Mbps .
Additional Information:
IP Profile for your line is - 38.01 Mbps
2. Upstream Test: -provides background information.
Upload Speed
7.99 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 7.99Mbps
Upstream Rate IP profile on your line is - 10 Mbps
pippincp
Message 8 of 10
A look at the connection stats from your hub would be advisable too. Which hub have you got?
Gareth064
Message 9 of 10
Is this what you are looking for?
1. Product Name: HomeHub5
2. Serial number: +076286+1602006792
3. Firmware version: v0.07.06.09028-BT (Type B) Last updated 27/10/2016
4. Board version: 01
5. VDSL uptime: 0 days, 03:51:10
6. Data Rate: 9866 / 39307
7. Maximum Data Rate: 9896 / 39488
8. Noise Margin: 5.7 / 6.3
9. Line Attenuation: 35.9 / 23.7
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 174.3 MB / 2.2 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4GHz wireless network/SSID: BTHub5-7363
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub5-7363 5ghz
19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: a8:d3:f7:b9:b6:c5
24. Software variant: -
25. Boot loader: 0.5.1-BT (Wed Nov 12 11:52:05 2014)
pippincp
Message 10 of 10
Yes, they're OK. It looks like you have a bit of congestion during the day as well. That should be resolved at the same time.
