Message 21 of 26
Re: Extremely high ping times (> 3000ms) and unusable speeds (< 0.5 Mbps) with BT Broadband. L
Still awaiting contact from BT staff, this mornings latency, 1112.307ms Avg, with a 6.2% pakcet loss :-
PING bbc.co.uk (212.58.246.103): 56 data bytes
Request timeout for icmp_seq 0
64 bytes from 212.58.246.103: icmp_seq=0 ttl=51 time=1118.983 ms
64 bytes from 212.58.246.103: icmp_seq=1 ttl=51 time=1091.728 ms
64 bytes from 212.58.246.103: icmp_seq=2 ttl=51 time=1103.393 ms
64 bytes from 212.58.246.103: icmp_seq=3 ttl=51 time=1090.056 ms
64 bytes from 212.58.246.103: icmp_seq=4 ttl=51 time=1105.621 ms
64 bytes from 212.58.246.103: icmp_seq=5 ttl=51 time=1115.464 ms
64 bytes from 212.58.246.103: icmp_seq=6 ttl=51 time=1103.145 ms
64 bytes from 212.58.246.103: icmp_seq=7 ttl=51 time=1093.784 ms
64 bytes from 212.58.246.103: icmp_seq=8 ttl=51 time=1104.089 ms
64 bytes from 212.58.246.103: icmp_seq=9 ttl=51 time=1113.955 ms
64 bytes from 212.58.246.103: icmp_seq=10 ttl=51 time=1100.058 ms
64 bytes from 212.58.246.103: icmp_seq=11 ttl=51 time=1114.992 ms
64 bytes from 212.58.246.103: icmp_seq=12 ttl=51 time=1101.355 ms
64 bytes from 212.58.246.103: icmp_seq=13 ttl=51 time=1112.196 ms
64 bytes from 212.58.246.103: icmp_seq=14 ttl=51 time=1100.233 ms
64 bytes from 212.58.246.103: icmp_seq=15 ttl=51 time=1136.493 ms
64 bytes from 212.58.246.103: icmp_seq=16 ttl=51 time=1127.030 ms
64 bytes from 212.58.246.103: icmp_seq=17 ttl=51 time=1117.445 ms
64 bytes from 212.58.246.103: icmp_seq=18 ttl=51 time=1106.690 ms
64 bytes from 212.58.246.103: icmp_seq=19 ttl=51 time=1120.682 ms
64 bytes from 212.58.246.103: icmp_seq=20 ttl=51 time=1111.387 ms
64 bytes from 212.58.246.103: icmp_seq=21 ttl=51 time=1126.100 ms
64 bytes from 212.58.246.103: icmp_seq=22 ttl=51 time=1115.446 ms
64 bytes from 212.58.246.103: icmp_seq=23 ttl=51 time=1130.390 ms
64 bytes from 212.58.246.103: icmp_seq=24 ttl=51 time=1118.692 ms
64 bytes from 212.58.246.103: icmp_seq=25 ttl=51 time=1129.313 ms
64 bytes from 212.58.246.103: icmp_seq=26 ttl=51 time=1114.956 ms
64 bytes from 212.58.246.103: icmp_seq=27 ttl=51 time=1124.999 ms
64 bytes from 212.58.246.103: icmp_seq=28 ttl=51 time=1115.094 ms
64 bytes from 212.58.246.103: icmp_seq=29 ttl=51 time=1105.428 ms
^C
--- bbc.co.uk ping statistics ---
32 packets transmitted, 30 packets received, 6.2% packet loss
round-trip min/avg/max/stddev = 1090.056/1112.307/1136.493/11.588 ms
Message 22 of 26
the mods are currently very busy but they will get back to as soon as they can
Message 23 of 26
I understand that the Moderators are busy, I have spent many years within the service industry (in electrical engineering) so I know how busy things can get sometimes.
The point is we are paying for a broadband service that we are simply not receiving, it works sometimes then others it's simply awful. If I were to take the attitude "I'll will pay the bill when we can" I'm sure BT would be onto me pretty damned quickly.
If someone was for example paying monthly to rent a car then found that it worked sometimes and not others they would rightly expect the problem to be resolved. I am not sure they wouldn't be happy to hear "We'll look at it when we can" but in the meantime just keep on paying.
I have BT infinty at my other address and cant speak of it highly enough but this situation is simply very poor. I would not recommend this product to anyone.
Moderator
Moderator
Message 24 of 26
Hi Unix_Guy,
Sorry for the delay getting back to you.
I've checked our email queue and you're more or less at the top now so it won't be long before one of the mods gets in touch to help.
Cheers,
Robbie
Message 25 of 26
High latency & slow download speeds can also be a symptom of high traffic load, are there any devices running P2P on the network? or is it possible that a device has been compromised or the wifi hijacked? if there is P2P traffic, try and limit the max. sockets to below 300, alternatively, run wireshark or similar on the wifi to check for unknown / unauthorised traffic
Message 26 of 26
No there is not any  P2P stuff on our network, don't have wireshark at the moment but I have checked the HH4 for any unusual connections but nothing other than our laptops.
The issue is more to do with latency not so much speed, our bandwidth is unfortunately limited as we are in rural area (We have fiber to the exchange but not to the cab... yet).
From running a few tests this end we are experiencing a lot of very high latency and dropouts causing packet loss, ultimately giving unreliable broadband. BT have contacted me a few minutes ago and would like to do more tests, I was trying to explain to them that this is not just a bandwidth problem as we will never get a high speed connection until OpenReach role out FTTC. Ultimately high latency, packet loss, and dropouts will cause even the fastest connection to seem slow.
Today's pings results show greatly improved overall latency infact a pretty healthy latency....but still dropouts on this occasion leading to a 9.4% packet loss (with only 64 bytes of data!) this is part of the overall the problem. But it does seem improved just need to find out the cause of these dropouts.
Last login: Fri Jul 10 10:09:37 on ttys000
MacBook-Pro:~ Admin$ ping bbc.co.uk
PING bbc.co.uk (212.58.244.20): 56 data bytes
64 bytes from 212.58.244.20: icmp_seq=0 ttl=50 time=71.025 ms
64 bytes from 212.58.244.20: icmp_seq=1 ttl=50 time=39.551 ms
64 bytes from 212.58.244.20: icmp_seq=2 ttl=50 time=39.327 ms
64 bytes from 212.58.244.20: icmp_seq=3 ttl=50 time=39.547 ms
64 bytes from 212.58.244.20: icmp_seq=4 ttl=50 time=39.291 ms
64 bytes from 212.58.244.20: icmp_seq=5 ttl=50 time=39.684 ms
64 bytes from 212.58.244.20: icmp_seq=6 ttl=50 time=39.384 ms
64 bytes from 212.58.244.20: icmp_seq=7 ttl=50 time=40.093 ms
64 bytes from 212.58.244.20: icmp_seq=8 ttl=50 time=39.899 ms
64 bytes from 212.58.244.20: icmp_seq=9 ttl=50 time=39.567 ms
64 bytes from 212.58.244.20: icmp_seq=10 ttl=50 time=39.392 ms
64 bytes from 212.58.244.20: icmp_seq=11 ttl=50 time=39.155 ms
64 bytes from 212.58.244.20: icmp_seq=12 ttl=50 time=38.962 ms
64 bytes from 212.58.244.20: icmp_seq=13 ttl=50 time=40.191 ms
64 bytes from 212.58.244.20: icmp_seq=14 ttl=50 time=39.599 ms
64 bytes from 212.58.244.20: icmp_seq=15 ttl=50 time=39.390 ms
64 bytes from 212.58.244.20: icmp_seq=16 ttl=50 time=39.146 ms
64 bytes from 212.58.244.20: icmp_seq=17 ttl=50 time=39.666 ms
64 bytes from 212.58.244.20: icmp_seq=18 ttl=50 time=39.481 ms
64 bytes from 212.58.244.20: icmp_seq=19 ttl=50 time=39.517 ms
64 bytes from 212.58.244.20: icmp_seq=20 ttl=50 time=39.303 ms
64 bytes from 212.58.244.20: icmp_seq=21 ttl=50 time=39.272 ms
64 bytes from 212.58.244.20: icmp_seq=22 ttl=50 time=39.921 ms
64 bytes from 212.58.244.20: icmp_seq=23 ttl=50 time=40.658 ms
64 bytes from 212.58.244.20: icmp_seq=24 ttl=50 time=40.389 ms
64 bytes from 212.58.244.20: icmp_seq=25 ttl=50 time=39.514 ms
64 bytes from 212.58.244.20: icmp_seq=26 ttl=50 time=41.010 ms
64 bytes from 212.58.244.20: icmp_seq=27 ttl=50 time=39.958 ms
64 bytes from 212.58.244.20: icmp_seq=28 ttl=50 time=39.882 ms
64 bytes from 212.58.244.20: icmp_seq=29 ttl=50 time=40.676 ms
64 bytes from 212.58.244.20: icmp_seq=30 ttl=50 time=40.651 ms
64 bytes from 212.58.244.20: icmp_seq=31 ttl=50 time=40.049 ms
64 bytes from 212.58.244.20: icmp_seq=32 ttl=50 time=39.558 ms
64 bytes from 212.58.244.20: icmp_seq=33 ttl=50 time=41.029 ms
64 bytes from 212.58.244.20: icmp_seq=34 ttl=50 time=40.801 ms
64 bytes from 212.58.244.20: icmp_seq=35 ttl=50 time=39.979 ms
64 bytes from 212.58.244.20: icmp_seq=36 ttl=50 time=39.991 ms
64 bytes from 212.58.244.20: icmp_seq=37 ttl=50 time=39.787 ms
64 bytes from 212.58.244.20: icmp_seq=38 ttl=50 time=39.548 ms
64 bytes from 212.58.244.20: icmp_seq=39 ttl=50 time=41.302 ms
64 bytes from 212.58.244.20: icmp_seq=40 ttl=50 time=40.350 ms
64 bytes from 212.58.244.20: icmp_seq=41 ttl=50 time=40.890 ms
64 bytes from 212.58.244.20: icmp_seq=42 ttl=50 time=40.203 ms
64 bytes from 212.58.244.20: icmp_seq=43 ttl=50 time=39.951 ms
64 bytes from 212.58.244.20: icmp_seq=44 ttl=50 time=42.115 ms
64 bytes from 212.58.244.20: icmp_seq=45 ttl=50 time=41.205 ms
64 bytes from 212.58.244.20: icmp_seq=46 ttl=50 time=40.398 ms
64 bytes from 212.58.244.20: icmp_seq=47 ttl=50 time=40.779 ms
64 bytes from 212.58.244.20: icmp_seq=48 ttl=50 time=40.763 ms
64 bytes from 212.58.244.20: icmp_seq=49 ttl=50 time=40.776 ms
64 bytes from 212.58.244.20: icmp_seq=50 ttl=50 time=41.506 ms
64 bytes from 212.58.244.20: icmp_seq=51 ttl=50 time=41.282 ms
64 bytes from 212.58.244.20: icmp_seq=52 ttl=50 time=40.187 ms
64 bytes from 212.58.244.20: icmp_seq=53 ttl=50 time=39.991 ms
64 bytes from 212.58.244.20: icmp_seq=54 ttl=50 time=40.993 ms
64 bytes from 212.58.244.20: icmp_seq=55 ttl=50 time=40.702 ms
64 bytes from 212.58.244.20: icmp_seq=56 ttl=50 time=40.430 ms
64 bytes from 212.58.244.20: icmp_seq=57 ttl=50 time=40.254 ms
64 bytes from 212.58.244.20: icmp_seq=58 ttl=50 time=40.051 ms
64 bytes from 212.58.244.20: icmp_seq=59 ttl=50 time=40.547 ms
64 bytes from 212.58.244.20: icmp_seq=60 ttl=50 time=40.595 ms
64 bytes from 212.58.244.20: icmp_seq=61 ttl=50 time=39.660 ms
64 bytes from 212.58.244.20: icmp_seq=62 ttl=50 time=40.157 ms
64 bytes from 212.58.244.20: icmp_seq=63 ttl=50 time=39.933 ms
64 bytes from 212.58.244.20: icmp_seq=64 ttl=50 time=40.664 ms
64 bytes from 212.58.244.20: icmp_seq=65 ttl=50 time=40.679 ms
64 bytes from 212.58.244.20: icmp_seq=66 ttl=50 time=40.490 ms
64 bytes from 212.58.244.20: icmp_seq=67 ttl=50 time=40.261 ms
64 bytes from 212.58.244.20: icmp_seq=68 ttl=50 time=40.315 ms
64 bytes from 212.58.244.20: icmp_seq=69 ttl=50 time=40.091 ms
64 bytes from 212.58.244.20: icmp_seq=70 ttl=50 time=39.894 ms
64 bytes from 212.58.244.20: icmp_seq=71 ttl=50 time=39.650 ms
64 bytes from 212.58.244.20: icmp_seq=72 ttl=50 time=39.388 ms
64 bytes from 212.58.244.20: icmp_seq=73 ttl=50 time=39.967 ms
64 bytes from 212.58.244.20: icmp_seq=74 ttl=50 time=39.760 ms
64 bytes from 212.58.244.20: icmp_seq=75 ttl=50 time=40.678 ms
64 bytes from 212.58.244.20: icmp_seq=76 ttl=50 time=40.780 ms
64 bytes from 212.58.244.20: icmp_seq=77 ttl=50 time=40.540 ms
64 bytes from 212.58.244.20: icmp_seq=78 ttl=50 time=40.314 ms
64 bytes from 212.58.244.20: icmp_seq=79 ttl=50 time=40.095 ms
64 bytes from 212.58.244.20: icmp_seq=80 ttl=50 time=39.876 ms
64 bytes from 212.58.244.20: icmp_seq=81 ttl=50 time=40.251 ms
64 bytes from 212.58.244.20: icmp_seq=82 ttl=50 time=40.364 ms
64 bytes from 212.58.244.20: icmp_seq=83 ttl=50 time=40.302 ms
64 bytes from 212.58.244.20: icmp_seq=84 ttl=50 time=39.899 ms
64 bytes from 212.58.244.20: icmp_seq=85 ttl=50 time=41.812 ms
64 bytes from 212.58.244.20: icmp_seq=86 ttl=50 time=41.716 ms
64 bytes from 212.58.244.20: icmp_seq=87 ttl=50 time=40.375 ms
Request timeout for icmp_seq 88
Request timeout for icmp_seq 89
Request timeout for icmp_seq 90
64 bytes from 212.58.244.20: icmp_seq=91 ttl=50 time=39.693 ms
64 bytes from 212.58.244.20: icmp_seq=92 ttl=50 time=39.611 ms
64 bytes from 212.58.244.20: icmp_seq=93 ttl=50 time=40.538 ms
64 bytes from 212.58.244.20: icmp_seq=94 ttl=50 time=40.590 ms
64 bytes from 212.58.244.20: icmp_seq=95 ttl=50 time=40.390 ms
64 bytes from 212.58.244.20: icmp_seq=96 ttl=50 time=40.164 ms
64 bytes from 212.58.244.20: icmp_seq=97 ttl=50 time=40.669 ms
64 bytes from 212.58.244.20: icmp_seq=98 ttl=50 time=39.745 ms
64 bytes from 212.58.244.20: icmp_seq=99 ttl=50 time=40.212 ms
64 bytes from 212.58.244.20: icmp_seq=100 ttl=50 time=39.877 ms
64 bytes from 212.58.244.20: icmp_seq=101 ttl=50 time=40.529 ms
64 bytes from 212.58.244.20: icmp_seq=102 ttl=50 time=40.482 ms
64 bytes from 212.58.244.20: icmp_seq=103 ttl=50 time=40.244 ms
64 bytes from 212.58.244.20: icmp_seq=104 ttl=50 time=40.026 ms
64 bytes from 212.58.244.20: icmp_seq=105 ttl=50 time=39.825 ms
64 bytes from 212.58.244.20: icmp_seq=106 ttl=50 time=39.633 ms
64 bytes from 212.58.244.20: icmp_seq=107 ttl=50 time=39.392 ms
64 bytes from 212.58.244.20: icmp_seq=108 ttl=50 time=39.902 ms
64 bytes from 212.58.244.20: icmp_seq=109 ttl=50 time=39.860 ms
Request timeout for icmp_seq 110
64 bytes from 212.58.244.20: icmp_seq=111 ttl=50 time=40.536 ms
64 bytes from 212.58.244.20: icmp_seq=112 ttl=50 time=40.433 ms
64 bytes from 212.58.244.20: icmp_seq=113 ttl=50 time=40.326 ms
64 bytes from 212.58.244.20: icmp_seq=114 ttl=50 time=40.066 ms
64 bytes from 212.58.244.20: icmp_seq=115 ttl=50 time=40.663 ms
64 bytes from 212.58.244.20: icmp_seq=116 ttl=50 time=41.729 ms
64 bytes from 212.58.244.20: icmp_seq=117 ttl=50 time=40.075 ms
64 bytes from 212.58.244.20: icmp_seq=118 ttl=50 time=39.930 ms
64 bytes from 212.58.244.20: icmp_seq=119 ttl=50 time=39.712 ms
64 bytes from 212.58.244.20: icmp_seq=120 ttl=50 time=39.477 ms
64 bytes from 212.58.244.20: icmp_seq=121 ttl=50 time=40.089 ms
64 bytes from 212.58.244.20: icmp_seq=122 ttl=50 time=41.083 ms
64 bytes from 212.58.244.20: icmp_seq=123 ttl=50 time=40.829 ms
64 bytes from 212.58.244.20: icmp_seq=124 ttl=50 time=40.869 ms
64 bytes from 212.58.244.20: icmp_seq=125 ttl=50 time=40.667 ms
64 bytes from 212.58.244.20: icmp_seq=126 ttl=50 time=40.643 ms
64 bytes from 212.58.244.20: icmp_seq=127 ttl=50 time=40.497 ms
64 bytes from 212.58.244.20: icmp_seq=128 ttl=50 time=42.103 ms
64 bytes from 212.58.244.20: icmp_seq=129 ttl=50 time=40.359 ms
64 bytes from 212.58.244.20: icmp_seq=130 ttl=50 time=41.915 ms
64 bytes from 212.58.244.20: icmp_seq=131 ttl=50 time=41.559 ms
64 bytes from 212.58.244.20: icmp_seq=132 ttl=50 time=41.751 ms
64 bytes from 212.58.244.20: icmp_seq=133 ttl=50 time=40.676 ms
64 bytes from 212.58.244.20: icmp_seq=134 ttl=50 time=40.294 ms
64 bytes from 212.58.244.20: icmp_seq=135 ttl=50 time=41.433 ms
64 bytes from 212.58.244.20: icmp_seq=136 ttl=50 time=41.295 ms
64 bytes from 212.58.244.20: icmp_seq=137 ttl=50 time=41.190 ms
64 bytes from 212.58.244.20: icmp_seq=138 ttl=50 time=41.084 ms
64 bytes from 212.58.244.20: icmp_seq=139 ttl=50 time=41.685 ms
64 bytes from 212.58.244.20: icmp_seq=140 ttl=50 time=40.341 ms
64 bytes from 212.58.244.20: icmp_seq=141 ttl=50 time=40.515 ms
64 bytes from 212.58.244.20: icmp_seq=142 ttl=50 time=40.253 ms
64 bytes from 212.58.244.20: icmp_seq=143 ttl=50 time=41.222 ms
64 bytes from 212.58.244.20: icmp_seq=144 ttl=50 time=38.953 ms
64 bytes from 212.58.244.20: icmp_seq=145 ttl=50 time=39.757 ms
64 bytes from 212.58.244.20: icmp_seq=146 ttl=50 time=39.721 ms
64 bytes from 212.58.244.20: icmp_seq=147 ttl=50 time=40.799 ms
64 bytes from 212.58.244.20: icmp_seq=148 ttl=50 time=40.586 ms
64 bytes from 212.58.244.20: icmp_seq=149 ttl=50 time=40.427 ms
64 bytes from 212.58.244.20: icmp_seq=150 ttl=50 time=39.105 ms
64 bytes from 212.58.244.20: icmp_seq=151 ttl=50 time=40.648 ms
64 bytes from 212.58.244.20: icmp_seq=152 ttl=50 time=40.410 ms
64 bytes from 212.58.244.20: icmp_seq=153 ttl=50 time=40.403 ms
64 bytes from 212.58.244.20: icmp_seq=154 ttl=50 time=39.238 ms
64 bytes from 212.58.244.20: icmp_seq=155 ttl=50 time=40.119 ms
64 bytes from 212.58.244.20: icmp_seq=156 ttl=50 time=39.985 ms
64 bytes from 212.58.244.20: icmp_seq=157 ttl=50 time=39.762 ms
Request timeout for icmp_seq 158
Request timeout for icmp_seq 159
Request timeout for icmp_seq 160
Request timeout for icmp_seq 161
Request timeout for icmp_seq 162
Request timeout for icmp_seq 163
Request timeout for icmp_seq 164
Request timeout for icmp_seq 165
Request timeout for icmp_seq 166
Request timeout for icmp_seq 167
Request timeout for icmp_seq 168
Request timeout for icmp_seq 169
Request timeout for icmp_seq 170
Request timeout for icmp_seq 171
Request timeout for icmp_seq 172
64 bytes from 212.58.244.20: icmp_seq=173 ttl=50 time=40.509 ms
64 bytes from 212.58.244.20: icmp_seq=174 ttl=50 time=41.204 ms
64 bytes from 212.58.244.20: icmp_seq=175 ttl=50 time=40.245 ms
64 bytes from 212.58.244.20: icmp_seq=176 ttl=50 time=40.054 ms
64 bytes from 212.58.244.20: icmp_seq=177 ttl=50 time=39.755 ms
64 bytes from 212.58.244.20: icmp_seq=178 ttl=50 time=39.518 ms
64 bytes from 212.58.244.20: icmp_seq=179 ttl=50 time=40.292 ms
64 bytes from 212.58.244.20: icmp_seq=180 ttl=50 time=40.025 ms
64 bytes from 212.58.244.20: icmp_seq=181 ttl=50 time=40.116 ms
64 bytes from 212.58.244.20: icmp_seq=182 ttl=50 time=40.135 ms
64 bytes from 212.58.244.20: icmp_seq=183 ttl=50 time=39.646 ms
64 bytes from 212.58.244.20: icmp_seq=184 ttl=50 time=40.414 ms
64 bytes from 212.58.244.20: icmp_seq=185 ttl=50 time=39.209 ms
64 bytes from 212.58.244.20: icmp_seq=186 ttl=50 time=40.658 ms
64 bytes from 212.58.244.20: icmp_seq=187 ttl=50 time=40.469 ms
64 bytes from 212.58.244.20: icmp_seq=188 ttl=50 time=40.278 ms
64 bytes from 212.58.244.20: icmp_seq=189 ttl=50 time=41.538 ms
64 bytes from 212.58.244.20: icmp_seq=190 ttl=50 time=40.240 ms
64 bytes from 212.58.244.20: icmp_seq=191 ttl=50 time=41.054 ms
64 bytes from 212.58.244.20: icmp_seq=192 ttl=50 time=39.816 ms
64 bytes from 212.58.244.20: icmp_seq=193 ttl=50 time=39.390 ms
64 bytes from 212.58.244.20: icmp_seq=194 ttl=50 time=39.893 ms
64 bytes from 212.58.244.20: icmp_seq=195 ttl=50 time=39.628 ms
64 bytes from 212.58.244.20: icmp_seq=196 ttl=50 time=39.591 ms
64 bytes from 212.58.244.20: icmp_seq=197 ttl=50 time=40.368 ms
64 bytes from 212.58.244.20: icmp_seq=198 ttl=50 time=40.343 ms
64 bytes from 212.58.244.20: icmp_seq=199 ttl=50 time=40.161 ms
64 bytes from 212.58.244.20: icmp_seq=200 ttl=50 time=40.957 ms
64 bytes from 212.58.244.20: icmp_seq=201 ttl=50 time=40.978 ms
64 bytes from 212.58.244.20: icmp_seq=202 ttl=50 time=39.497 ms
^C
203 packets transmitted, 184 packets received, 9.4% packet loss
round-trip min/avg/max/stddev = 38.953/40.433/71.025/2.353 ms
