overthehedge
Message 1 of 35
Extremely low infinity speed
Hi all,
I’m getting a download speed of between 10 and 15mb, I’ve had infinity for over a year, any idea how I can speed it up please?!?
34 REPLIES 34
overthehedge
Message 2 of 35
Re: Extremely low infinity speed
Just tried to do the test check with my telephone number, I get this message:
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line.
imjolly
Message 3 of 35
Can you post stats from your router
can you enter your phone number And post results. Remember to delete number https://www.dslchecker.bt.com/
arbe you using the test socket?
overthehedge
Message 4 of 35
Hi,
Unfortunately that test isn’t working for me, I’ve just done a test on the bt website and they’ve found a fault on my line and will aim to fix within four days so I will wait for that and see if it makes any different!
Many thanks
imjolly
Message 5 of 35
What about router stats
overthehedge
Message 6 of 35
overthehedge
Message 7 of 35
Hi Imjolly,
I have added the stats from the link you posted above
BT have now fixed the fault on the line but I’m still getting a download speed of 25mbps and an upload speed of 8.9mbps, this is lower then the figures I get for my mobile data, surely this isn’t correct?
Many thanks 🙂
overthehedge
Message 8 of 35
Also should have said, I have BT infinity 1,
pippincp
Message 9 of 35
See HERE and post your hub connection stats pls.
overthehedge
Message 10 of 35
Hi Pippincp,
I’ve done the test imjolly asked for and results are posted above, I cannot do your test as it says I do not have flash player and cannot install it (I’m using a tablet)
